nico-sg
Aqara neutral switch is not rated for water heater 20A switch which is double pole (L/N) switch with Earth connection. They are only meant for light switches with the specified current ratings. Search the thread for the possible solutions for 20A heater switch. Light switches here in SG typically don't have earth connection, only the higher current 13A onwards have earth.
Neutral wire installation doesn't necessarily mean it is left 'hanging' there, you can ask electrician to terminate it properly until the smart switch installation then remove the screw terminal block or wago connector.
Hi zoneguard, all
Thanks for your reply
Understood for the water heater, I remember reading throught this article:
lesterchan.net/blog/2016/07/14/using-mco-touch-panel-with-storage-water-heater/?utm_source=search-post&utm_medium=web&utm_campaign=%2Fblog%2F2016%2F07%2F14%2Fusing-mco-touch-panel-with-storage-water-heater%2F
Is it the best option for a fresh new setup/renovation?
I had further discussion with my contractor, they mentioned TOP/BCA Inspection will fail if they see a neutral wire, not connected, behind the switches. What to do? I can't ask them to re-wire post TOP. Is Neutral wire behind every switch going to be the standard in Singapore? When new HDB will become smart, do you know which standard they will apply?
I went to Xiaomi store in Funan yesterday, they sell the Aqara hub, sensor,... but no switch, I find the solution a bit useless as you would need to stuck to Xiaomi bulb or their limited light fixture. I don't think the switch will come in in the near future, what is your take?
doppelgriff
I didn’t expect 2 way to have different complicated wiring hence didn’t expect livolo wouldn’t support. However you don’t have to be sarcastic. I never claimed to be an expert hence I asked if anyone has experience doing this.
Based on what I’ve learned I think livolo can only handle one of the gangs being two ways and not both. And of course the website doesn’t say so. The seller claims it’s support but I suspect that’s just so products can be sold.
3 locations (A,B,C):
A: 2 gang
B: 2 gang
C: 3 gang
Connection:
2 gang switch at A 2 way with 2 gang at B
2 gang at B 2 way with 3 gang at C?
Question: What makes you think your configuration is actually supported by Livolo?
zoneguard
In terms of time with the 1st being the oldest solution
1. Contactor. Lester's method.
2. eTouch 20A heater switch. Sold on Carousell.
3. Switchbot or Roome. Install over the existing 20A heater switch. https://forums.hardwarezone.com.sg/121511252-post1695.html has some details.
4. Tuya heater switch. https://forums.hardwarezone.com.sg/121629884-post1705.html.
To me, this is the contractor's smokescreen not to install neutral wire. Anyway you can always verify with another contractor. BTW are you building a new house? Condo/HDB's TOP is awarded before electrical installation AFAIK. I could be wrong.
There are posts weighing pros/cons of smart switch vs smart lighting in this thread.
zoneguard
For me, I verified my particular setup is supported with the seller and others' setup before the purchase as I didn't want to end up buying switches that I couldn't use.
I have a suggestion: Two-way switches can be eliminated at the second/third locations - your electrician should know what to do with regards to the connections. You can control the switch via voice/wireless switch/app at the second/third locations. At the purchase decision point, I was choosing between Broadlink and Livolo and chose to eliminate the 2-way switches from my setup to simplify the connections and control the switches through other means at the next locations.
Elon Jobs
Personally, I feel two way switch is overrated in the era of home automation. I’m not sure how big is your house, but my five room BTO came with two-way mechanical switch for the living room. When I upgraded to my current eTouch switches (together with RM Pro and GHMs), I had to do away with the two-way switches. To be honest, I didn’t even notice the difference.
I can now use my voice to turn on or off the switches, or use the phone app when I don’t want to wake the rest of the family up.
pustefix
Well we use home assistant but not with zwave stick, so maybe you are alone? Zoneguard and me uses Zigbee2MQTT.
Is home automation practical? Or is it just to step atas and waste electricity? If its just to save u the hassle of flipping the light switch, then I can't see why I want to do that instead of walking to the switch and do it myself.
Saving one step is usually enough for user to switch, e.g. using my phone to pay has make me almost curse and swear when the shop needs me to dig out my wallet. Once you are used to the convenience, you will not want to go back. Home automation is also more than flipping a switch, my vacuum cleaner will clean the house when everyone is out, there is bus timing announcement on my Goggle Home speaker, etc.
doppelgriff
Seller verified but China seller so I don’t always get the most accurate answer
Yes, that was the plan. To eliminate 2 ways and just wire them as 1 way. The problem was after the wiring, whenever I turned on any of the 2 gang switches (the one where both gangs are two ways), it switched both the devices off instead of the device wired to that gang. And sometimes it would switch off all the lights on the 3 gang. Basically it was interfering. After watching the 2 gang back to a normal plastic switch the 3 gang one now works as one way.
I tried reading and researching but didn’t find enough info hence I posted here to ask
zoneguard
Other use cases (mine):
1. Multi Room Audio with Spotify/Amazon Music.
2. Home Entertainment (Videos/Music).
3. Information (Weather, Air Quality, Schedule, Electricity Consumption)
4. Hands-free phone calls.
The list goes on.
zoneguard
From your description, either the electrician didn't know what he was doing or there is something wrong with the Livolo switches or their setup. I really cannot tell at this point.
A connection diagram of the current setup will be helpful to diagnose the issues. Or unless some home automation companies in SG regularly install Livolo switches for customers and have the experience/expertise to fault-find for you for a fee. The more popular brand here in the thread however is Broadlink.
viix
I think you misunderstood the word Automation.. it means auto. Home automation allows you to use voice assistant and a touch screen device to control your devices, but the idea of it is to automate task that are routine to reduce the hassle of it.
Unfortunately not many installers or DIYer venture beyond installing the devices and app. One is suppose to integrate sensors or some time/location based scheduling to reduce the redundant stuff so you can enjoy a better quality of life.
Having switches is only because the more traditional visitors like to see the status of the circuit and like flicking switches to off. :s22:
Why would you want to wire it two way? I have a few two way switches at my place too and I terminated it to be powered to two individual separate switch and let the switch/hub handle the status update. (zwave association in my case)
zoneguard
If you prefer to buy from Lazada (promo/deals/coupon etc),
these 2 items look similar to the last one:
1. https://www.lazada.sg/products/quiv...-alexa-google-home-i376770534-s882518836.html.
2. https://www.lazada.sg/products/nice...-maker-bread-maker-i339490784-s750244929.html.
CyberMew
Is there a motor for blinds? I only got one continuous chain to raise or lower the blinds, and my slatted blinds and flip in one direction or the other. I read about Brunt but I think mine is too heavy for it to rotate the chain.
baineteo
Hi all,
I've been reading up quite a bit on home automation and would like to start playing around with my new BTO. I have already 'future proofed' my place with neutral wires at most wall switches, and decided to go with Aqara + Xiaomi/Aqara gateway to simplicity sake as a start. I have a few questions, that I hope the experts here can help with..
1) So I am aware that there is a Singapore and China gateway versions. Please correct me if I'm wrong, but the difference between the 2 is the China version has more options in terms of compatible devices, while the Singapore has lesser options for that. Is there a list of stuff that the Singapore one works with?
2) What is the difference between the Aqara Smart Hub gateway and the Mijia Gateway V2?
3) I foresee myself to do more than just Xiaomi stuff once I am familiar and comfortable. I may want t move to something like HA. What should I go for to ensure future compatibility?
4) What are the few recommended places to buy these items? PassionHome seems legit. I also noticed most people buy from Aliexpress instead of taobao. Is there a reason for that? I don't mind getting from taobao directly; anything to look out for?
5) What do I need to do to integrate with Somfy blinds?
A bit of context on what I plan to do:
- Link lights to smart switch as as start, so no need 2-way switches. Plan to put buttons at strategic locations to replace 2 ways.
- Toilet exhaust fan - to keep fan running after lights off (already catered for 1 more switch separate from light)
- Motion sensors to turn lights on
- Open/close blinds based on time (somfy motorised blinds)
- Can ceiling fan be connecteed to Aqara?
- Looking for good 3 and 4-gang smart switches.
Thank you! :)
scaredcloud
Home automation is not just about switches, there are so much more use cases when you need it. In my case, with only 2 in the house, there are tremendous applications:
A single command at night determined my next day alarm clock, the storage water heater turns on 10mins prior to the alarm clock. A simple "good morning" turns off air-con, turns on necessary lighting, starts "smooth jazz radio", makes coffee... When both of us left the house (outside network), everything turns off.
The vacuum cleans the house every weekdays at 5pm, air-purifier starts working the moment one of us left office, lights turned on when either of us is inbound after 6:45pm.
These are the daily routines...
Some rare use cases... e.g. the missus is afraid of dark and I travel a lot, hence she's always sleeping alone with the lights on, when detected she's asleep, lights and music are turned off, upon waking up before dawn, moonlight scene turns on.
While both of us are traveling, we can monitor the house and create random "home scenes" that mimics residential activities...
There are still so much more to explore... one's imagination is the limit.
pustefix
1) I don't think there is list of devices supported by Singapore server. If you plan to use Home Assistant or other platform in the future, it doesn't matter. You just need Mi Home for setting up the devices, once it is setup you can leave it alone and rely on HA for automation. It is also not a good idea to update the firmware, so really not much use of Mi Home app.
2) The Aqara gateway is the newer one with Apple Homekit support, however it doesn't work with open source platform e.g. HA.
3) Go to the platform that you are interested in and look at the device compatibility list.
4) I usually get the Xiaomi sensors from Shopee or Lazada. Taobao prices are not really good and they are hard to find too. It seems that for some electronics, it is easier and cheaper to get from local online shops and Aliexpress than from Taobao.
zoneguard
I got home automation stuff from PassionHome, Shopee, Lazada, qoo10, Aliexpress,Amazon and even eBay - main consideration is price , shipping time and merchants' ratings/reviews.
There aren't many choices for 4-gang smart switches. Most go up to 3 gang only.
wahjohreno
Yes, I use Somfy, both for my roller blinds and curtains.
wahjohreno
It’s pretty life changing to me. Changes your workflow.
With one command you set whole scenes, not just one light. You walk to a light, flip the switch, it turns on. Versus saying “I’m home” > your living and bedroom Aircon turns on and sets the temperature to 24 degs, your cove lights are set at exactly 12% brightness, your downlights are set at exactly 20% brightness, your security cam at home turns off, your water heater turns on, your table and floor lamps turn on, your tv turns on and sets the channel to CNN (or whatever you like)...
Before leaving the house, you just need to say “turn off everything”. And literally everything turns off. Or if you’re really in a rush, just leave and turn off everything with your phone on your way.
Endless possibilities.
You get the point.
Jas007
Sonoff users, any issues of wifi dropouts lately ?
was using ifan02, then swapped that out for dual RF ... but also started facing issues of broken wifi
can’t be locality coz it’s in the living room, and my airties is in the dining room
now pondering if i should swap out again in favour of 2 separate RF Basic; 1 for the ceiling light, 1 for ceiling fan ... unless i mod such that the SONOFF is connected close to the wall main switch of the light & fan ... that in the event of a broken wifi i can re-pair the device as opposed to having climb up on a ladder to the light housing where i’ve hidden the device
