Tuakong
- Jan 1, 2000
Yup it’s standalone but integrated with Alexa
What u gonna use got curtains?
there are 2 harmony skills be sure to install both. did you set activity with the harmony app??
My wife initially also don't understand why need voice command n automation. Press button can liao lor. Till recent we have a baby. When both hands are busy with baby, a simple voice command makes her life so much easier. Even before reaching home, can switch on the air con to cool the room first or turn on the living room lightsEverything should be able to be controlled manually as well.
I have friends who see my home automation and after i tell them how the devices work will automatically laugh and criticise if wifi down, nothing works.
Then when i tell them if no wifi i can manually on/off my things as per normal, they will say why have a smart home then
Think they need to justify to themselves why a smarthome is unnecessary.![]()
Wat appliances are managed by Harmony and Alexa?
I am trying to automate harmony and Alexa to switch cable channels
Dunno if it’s possible
Sent from OnePlus ONEPLUS A3010 using GAGT
anyone know if can convert FANCO ffm3000 radio frequency celing fan to WiFi controls or infra red controlled?
The fan motor a lot of wind at lvl 1 is good but the remote control cmi
Sent from Samsung SM-N910G using GAGT
I would like to know too
How to convert Fanco RF fans to zwave/zigbee/wifi and integrate with ST and Alexa
What i did was to connect wemo light switch to control my fan (not fanco but also using RF remote) . Basically just set the fan to your favourite speed and let it be. The switch just on/off (cut off / resume power) to the fan. It should start again at the speed that it was last on.
RF is next to impossible to program (unlike ir) so devices like Harmony will not work for them.
If you not sure if the fan remembers its last settings, throw the main db switch off while the ceiling fan is still running and turn it on again. If your fan starts spinning, any intelligent light switch will do.
Is your a floor standing fan or ceiling
I use WeMo for my floor lamps n integrated with Alexa n ST
I was looking for solutions for my ceiling fans to see if the RF can b converted to Zwave/zigbee or even wifi
Ceiling fan. And i am using both wemo switches (bought from amazon uk) as well as wemo light switches (bought from amazon us)
Can u control the fan speed?
If it*********s only off/on my Alexa n ST can do it
Cannot. How did you get ST to send RF to turn on/off your ceiling fan?
Regarding having smart control on ceiling fans, i came across bond. Looks promising if it can be programmed to control the fan..
