dragous
i have a client use their service. as they said, u just pay. u cant even access the configuration page. and pay yearly maintenance. but everything seems ok and good
Has anyone did home automation with home-a-genius? Can write a detailed review?
shacboi
Anybody try using the new broadlink app with Alexa or Google assistant? Is it still same as IHC app,?
Wanted to know if new broadlink app, does the A. I now recognise the respective modes rather than Google on lamp, and Alexa on TV template.
abramovich
The neutral wire is available at water heater and aircon power switch...electrician should know how to extend it...
But now new bto flats the wires r all hidden in the wall… so anyone of u who done pulling neutral wires to the light switches how is it done? Any ugly external trunking?
doran_lum
Does anyone know if it's possible to have automated plant watering especially when oversea ?
Sent from OnePlus GM1910 using GAGT
Alphas
Still have yearly maintenance, how much is it? :s11: If too expensive, I might as well DIY raspberry pi with home assistant and Node Red. :s12:
doinkz
Hello all,
I have 2 air conds - in the hall and room.
Room's air cond is not in the line of sight.
Anyone tried connecting two Mijia IR in the app?
Epi_curean
I got both the Control Outlet kit and Signal repeater. Both work with zigbee2mqtt for me, I am using version 1.5.0.
Please note that the Mi power plug has an issue with the Tradfri ON/OFF switch from the Control Outlet kit (all the power plugs will trigger on/off when the button goes on/off) and this bug is also resolved with the latest DEV branch of zigbee2mqtt.
Hi ,
How did you get the power adapter to be recognised by zigbee2mqtt? My tradfri bulbs were recognised instantly but not the power adapter.
regards
doki81
You 2 elite mah, $99 bucks for sensibo or ambi climate, I peasant niah. :(
back their first ambi since their first live on kickstarter...but I think..their AI not so good 1... bought liao..just use :(
Sent from Samsung Note 10 + using GAGT
baineteo
Has anyone tried connecting Aqara switches (with neutral) to exhaust fans before? I have one of the double gang switch connected to an exhaust fan, and the other one connected to lights. I suspect the light flashes (when turning on and off the exhaust fan) because of reverse current. Anyone has similar experience?
bullfrog
I didn't connect to an exhaust fan but to my ceiling fan and dining lights.
No flickering of dining lights when i off or on the ceiling fan. But it could be related to the power draw of ur exhaust fan when it first starts up.
Posted from PCWX using Me dic stinks
dragous
all smart switches cannot direct wire to fans or any motors. u will need to place a relay inbetween
