doki81
I've just bought tplink hs110 smart plug and realize that I can use it to remotely reboot my modem/router. Just need to set 2 schedules on the Kasa app, one to switch off and the another to switch on after 1 minute. The plug remember it last state, so make sure it is on before putting the plug on the modem/router.
What if after reboot...the router never come alive? You wont be able to reboot again then...as your tplink rely on the router to work?
Sent from Samsung Note 10 + using GAGT
Sammyfrog
Hi all!moving in soon to my place(wont be doing major reno) and keen to do up smart switches for the lighting but may need to (my guess) pull neutral wire from the lighting point to the switches (considering aqara wall switches). Any electricians to recommend? Cost effective and reliable.
Vulpix
Moderator
Moderator
I think any electrician worth their salt should be able to do it. You don't need any special skills to pull neutral to all your lighting point, maybe just ask your ID/contractor if they got someone to recommend.
Sammyfrog
Hi
Thanks. Will do so, thanks
doki81
The neutral wire is available at water heater and aircon power switch...electrician should know how to extend it...
dragous
or just take neutral from nearest power outlet or lightings
bullfrog
Google wifi MDNS broke
Hi Guys
Just wanted to update those using the xiaomi gateway + HomeAssistant+ Google Wifi, the solution is broken. It broke after Google pushed their latest firmware update to their Wifi devices.
MDNS no longer works between the mesh nodes. Google is aware of the problem and is working on it as it also affects their chromecast.
It affects my home setup as Hass.io no longer receives the info from the xiaomi gateway. What I see in the home-assistant.log is
ERROR (SyncWorker_9) [xiaomi_gateway] Got error element in data {"error":"Invalid key"}
This despite me confirming UDP ports 9898 and 4321 are open on the gateway using nmap. And that it has been working fine for months prior to the update.
So for those with Google Wifi, just sit tight. You should also notice weird discovery issues when using chromecast on your phone.
Link discussing the problem on reddit
https://www.reddit.com/r/GoogleWiFi/comments/dpnau0/client_isolation_issue/?utm_medium=android_app&utm_source=share
pustefix
Is there a way to disable the auto update of firmware for Google Wifi? The router is the backbone of all our networks and should be kept as stable as possible.
bullfrog
Not that I can find. Neither can I rollback to the earlier firmware. Was a pain finding out the root cause.
I even rebuilt HA on a new sdcard thinking maybe my HA or sdcard was the problem. Never thought the multicast function of Google wifi was broken as it used to work before. :(
Posted from PCWX using Me dic stinks
Vulpix
Moderator
Moderator
I cannot understand how this patch even made it out of their servers. So many people are affected.
bullfrog
Same. Especially since it affects their own chromecast product. Really face-palm
fateless
I intend to switch all my wall switch to smart one. Any recommendation on which wall switch can work in sg context? Intend to buy from ta Bao this 11.11
Willing to pay for contractor to change for me.
Alphas
Has anyone did home automation with home-a-genius? Can write a detailed review?
aeroplane
Hi, requiring assistance for my smart switches. I have installed all switches for wifi control using eWeLink app. Bought those switches from taobao, those that does not require any neutral wire, and worked alongside with capacitors.
Everything work out well with 1 issue. The lights will randomly auto on/off at random times, even if you did not schedule any timing for it.
Can i check if anyone have such issues b4, and have resolution for it?
AsusEpoxy
which brand did you buy? Sonoff? or some 3rd party brands that ride along on Ewelink servers?
dragous
if u disable ewlink app, will u have such issue? need to isolate the issue 1st
disable means delete the switch from the app...
i m testing 2 no-brand non-neutral switch, so far everything ok for 2 weeks
No hub. It was meant to connect to my home wifi network straight, which works fine using my phone to toggle on off and set scenes.
