AsusEpoxy
Hi Gurus,
I am starting on my home automation journey and would like to go for Xiaomi Gateway V3 and the smart switches (with neutral wire). Can anyone advise where can I purchase these items?
Was at Xiaomi store yesterday and they mentioned that they don't carry the Xiaomi smart switches (Aqara switches).
If you have tips on how to search on taobao for these items, please share the steps too.
Thank you!
its easier to go shopee and buy from zeyue imo.
tokenbest
Hi all,
1) interested in the xiaomi smart door lock (Aqara N200 or mi smart push pull door lock) but would need to put the mi home app to China server correct?
2) Is there any issue / disadvantage in setting the lock to china app or just personal pref?
Main thing is would like to start home automation when it detects whichever individual is home so other door locks are ok to if anyone have suggestions.
3) Also looking into using aqara wall light switches, what would be the issue if one is CN and one is SG server? Any work around if i were to use Home Assistant or Hubitat?
TIA!
baineteo
just control the "live" wire is sufficient, i dont see the need to control the "neutral". but it is always great to control both anyway. my advise is "live" control and "neutral" control are separated relays.
Reviving old post. My set up has been working fine for about 6 months, however it suddenly died today. No idea why. Symptoms are the same as before - switch is warm to touch, works for a while however after that it just stops responding.
baineteo
Hi all,
TIA!
Not sure you need to connect to Chinese server, so can’t help you with the lock. However my hub is connected to the Chinese server, and it is quite slow. I think you won’t find the lag acceptable for what you’re trying to do. Probably better to get HomeKit compatible lock (if Apple) or something else that does not use Aqara.
You can’t connect the wall switch to a Singapore server. You also can’t connect the Chinese gateway to a Singapore server. I heard you can use Aqara hub, though. I think it’s not country dependent.
tokenbest
Ok, thanks a lot. will see what i can do with the smart lock then. kind of a hassle when xiaomi product not locally compatible, such a waste.
heard aqara hub can connect directly to google home, so will see how to activate automation from there.
baineteo
I’m using iOS, and have Google home and home kit stuff. If you’re thinking of proper automation (like using sensor to trigger lights to on off, getting something to turn on at specific time automatically), Google home does not support that. Google home is an assistant, not automation. Assistant still needs you to trigger it; automations are triggered automatically. I wrote on my blog the differences here. http://housetosmart.com/2020/03/09/bubble-wrap-and-home-automation-whats-the-link/
You can’t set “if then statements” on Google home. So you can’t say if I’m home, turn on lights. Or if door opens, turn in lights.
davi502
Hi all,
TIA!
I'm also relatively new to the automation scene as compared to the experts and bros here.
Currently have a very simple aqara setup for my bedroom, to automate the switching of lights when motion is detected. I have set the Mi Home app region to China instead of Singapore.
I think the main issue here is whether the product you are trying to add in Mi Home is supported in that region ie China or Singapore. Usually for compatibility, most ppl will set to China region. And also so far all the devices I bought via Lazada were shipped from China, becos they are much cheaper compared to buying locally, but not exactly sure if they are region-locked. You can check with your seller on this info before deciding to buy.
Another thing to note is per Mi Home account, you can only choose one region to set, eg if you chose China region then all other devices that you add in that account will also be added to the China region / server. Not possible to choose region for individual devices in the same Mi Home account.
decker23
i installed the aqara wall switch and my led ceiling light keep flickering. Google that this is due to the non-netural switch.
Any one have some rough estimation on getting electrican to pull netural lines to about 8 switches throughout the house?
does ur light switch have a power socket beside it , you can tap the neutral from the power socket , just use a short cable and tap it from the power socket to the neutral
tokenbest
Bro, correct me if i am wrong.
But thought he is using a non-neutral switch and would have different connections than the neutral switch type?
Unless you mean that he need to buy a new switch with neutral and do the above as you said.
decker23
honestly the neutral switch is alot better, i done it last year and changed all my switches to netural type . it is more stable . no issues so far
fateless
I lost my Dyson fan remote. Currently using broad link rm pro to control.
Recently exploring to use Xiaomi zigbee control switch to turn on the Dyson fan through home assistant but the setup of broadlonk need to have a series of codes to be input.
Anyone has the Dyson Fan IR codes or where can I get it from internet?
tweety_piyo
buy a replacement remote from tao bao ...i got one from there for my TP00...works well
Tok Kong
I just bought a Sonoff RF bridge to control 433mhz from shopee.
It did recognise my 433mhz remote signal to learn. But it either doesn't broadcast or broadcast wrong frequency (learnt wrongly).
How to verified its dead on arrival? Anyone sucessfully paired it can check if mine's working?
BlackLab
Is the remote a Sonoff one as well?
Otherwise it's possible your remote uses rolling RF code, since the RF bridge can recognise signal but nothing happens when it broadcasts it.
Tok Kong
My 433 is definitely fixed code, dictated by the 8dips setting my existing remote control.
This is what the seller replied me: 'The device is shipped with Itead
e which supports a limited set of RF devices limited to mostly just devices (a single 24-bit RF protocol).'
I bought a broadlink pro+ and all is working well. :)
Sent from my ex bf account using GAGT
BlackLab
Yeah Sonoff's RF compatibility is really limited. I've only ever had luck with other Sonoff branded devices.
For RF control, Broadlink RM is the better bet.
Tee_bag
Aqara Wall Switches
Can the Aqara wall Switches be used without Aqara hubs?
ie: Can i just use the Aqara home app on my Andriod phone to control ? :s11:
davi502
Both Mi Home and Aqara Home App doesn't allow you to do so without first binding/adding to a hub.
Tee_bag
ic ic ... Thanks :D
So the usual case is like this right? :
(ie: toggle the on/off via Aqara Home app(android) )
Aqara Home App <-> Aqara Hub <-> Aqara wall switches
Can it be configured like this?
(ie: Hey Google .. turn off xxx Lights)
Google Home <-> Home Assistant <-> Aqara Hub <-> Aqara wall switches
:s11:
