viix
- Nov 17, 2001
Hi, got a wiring/cabling question..
Say if I want to position a Google nest hub max on the living room coffee table (between sofa and TV).. It's not quite possible to do the wiring without making it look ugly right? The wiring will be across the floor no matter what..
Anyone got idea how to make this better?
Hack the floor, or carpet with some super slim cabling/trucking.
I use a carpet, with a super slim wire RATED for the device under the carpet. Punch a hole in the carpet and run up the table. Issue solved. I stress rated cause if too thin, fire hazard as the wire will heat up. Mine is a DC device, so its a short run of cable under my electrical recliner to the console. AC, different story.
