-EnZo-
- Oct 28, 2008
neutral not necessary anymore because now got sell "no neutral" ones
i saw but i read like safer and more options less problems with neutral right?
sorry to hijack . so the combo to get for voice assist is google home , aqara hub and aqara switch . aqara sensor ( if lazy to voice assist ) . then neutral wire all the lighting points + ceiling fan . IR if want to pair all remote device.. as long as i have more smart switch with sensor i can add more automation rules right
right? i am missing anything?
For the minimum infrastructure preparation would you just get electrician to wire neutral first and use old skool switches-sockets? And say few years later when switch/socket is cheaper/improved can swap these out? If not, what is your suggestion? I prefer infrastructure hardwired not using that wifi/radio signals that seems to be the easy way out.
Thanks for the suggestion and yeah i've already read enough pages to say brands/systems are still in their infancy to go with for now. Same with the wifi bit so not concerned by that.If you are adding neutral to the switches, just use smart switches instead of old school ones. They are very usable in their current state, the difficult thing is choosing which brand/system to go with. Please note that the wires are for powering the switch, you still need wifi/radio signal for them to be smart so you can't do without the radio signals.
What happens if we just use normal switches firsts with the neutral wires?
I can't pay for smart switches now, need to keep wife happy and not sacrifice her tiles.
I know....have seen the evolution for many tech things hence getting the neutral wiring in place first. That seems to be the best common global standard whilst other companies ply their wireless standards all over the place. I haven’t even looked at differences between Alexa, google, apple etc yet so I’m not going to rush into this.nobody knows the future of smart home devices. Every company out there is trying to gain first mover advantage with their own protocol.
You have the old school systems like KNX and even C4 with their hardwired stuff which will require a server rack somewhere, or go with the current zwave/zigbee hubs.. or wifi but they are on 2.4g and you will probably need to have a good router to manage the traffic if you have alot of devices..
You can have neutral and use old switches but make sure your contractor terminate it behind the switch properly so there is not short.
Use smart controllers with RF 433 remote and smart plugs first.
Can upgrade later with WiFi smart switches and sockets later.
Not sure what neutral wires you’re talking about. Standard wiring?
I don’t know the terminology of wiring but here is my guess.
If you’re currently going to wire your light switches to toggle between two ends of the hall e.g. 3-gang light switch at each end of the hall to on/off three lights. If you want to go for WiFi switch later, you just need to change one end and leave the old manual 3-gang switch on all the time. I’m pretty sure you can change the other one too but it will be a double WiFi setup. Sockets? I don’t think it will be any issue if you change all to WiFi smart ones.
Google.
Homekit is limiting.
Alexa if you don’t like Google.
I will seriously consider your contractor advice if I’m in your shoes. If I ever do a full reno, I will just do that.
Looking for some advice or any recommendations.
Played around with home assistant on a rpi4 using conbee2 with zigbee2mqtt.
Noticed that pairing with Ikea Tradfri bulb and on/off remote needs to happen quite close to the conbee2. Does all zigbee devices need to be really close to the conbee2 (Ikea manual says 5cm)?
I am planning to install Aqara wall switches (with neutral, 12-15 switches ) around the house, up to 10-15m away, through walls, from the conbee2.
My worry is will I be able to pair to the conbee2 seeing they are quite far? Cause it’ll be a hassle to take out all the switches and bring it near the Rpi conbee2 to pair then re-install them one by one.
Heard the Tradfri repeaters are not too bad. Was thinking to start pairing them first, then place them in the rooms (since these are movable wall plugs). Also read that some models of Aqara switches work as a router?
So anyone has any recommendations what my installation process will be like or what I can expect? If the Aqara switches work as a router, would it be possible I just start pairing the ones nearest the Rpi n conbee, and slowly work my way away out (then i don’t really need a repeater/router like the Ikea tradfri)?
