Most of those appliances you mentioned probably use IR, which is line-of-sight, so yes, the RM4 Pro will work with it, but 1 room per device.
So 1) You put it in your living room where it is aimed at your Mitsubishi aircon, it will work.
Samsung TV - probably, if the remote uses IR and not RF. Fanco ceiling fan is probably RF too. Thing with RF is there's no guarantee it'll work, especially if the appliance uses rolling (encrypted) RF codes.
2) I don't use Google Assistant, but I think so.
3) A single device won't work on the other air-con units. Just imagine the signal is like you're pressing your remote controller from your living room, unlikely it'll reach the other rooms.
Even if it does, that means your one RM4 Pro is controlling multiple units at once, which I doubt is what you want. Cause that means you send an "aircon ON" command, all air-con in range will turn on instead.
4) Again, probably yes, but you need to position the RM4 in a spot where it can still send signals to both your air-con and your vacuum. (I'm assuming your Roborock is in the living room too.)
