IceX
For those using mihome,Anyone knows how come if I use siri to activate automation(my xiaomi table light and fan settings in my master bedroom), the settings is switched on correctly whereas if I use google home and voice command, the fan and table light will turn on but it’s the wrong settings ?
Chevalier
Hey guys, just wanted to check, for the signature heater switches sold on broadlink Lazada, when the led indicator is on, does that mean the heater is on?
blackestvoid
One way is to change your bulb to a smart one. Many smart bulbs support dimming. Problem with that is if someone turns off the light with a mechanical switch, that kills power to the bulbs. Alexa, Google home or smartapp can't help you turn it on again and someone needs to physically turn on the switch. As long as you have multiple people in the home, someone will turn off the bulbs via the light switch instead of app or Google home/alexa.
Posted from PCWX using SM-G988B
try this for smart mechanical switch
Alphas
The most elegant method is to use a smart 86mm socket dimmer with bulb that support dimming. Most bulbs cannot support dimming unless it’s a smart bulb but a mechanical switch will then defeat this purpose.
blackestvoid
pls do not mislead that only smart bulbs are dimmable
google and got so many eg of dimmable stupid bulbs
eg
https://www.wayfair.com/lighting/pdx/westinghouse-lighting-60-watt-equivalent-g40-led-dimmable-light-bulb-warm-white-2700k-e26-base-xbsh1640.html
60+Watt+Equivalent%252C+G40+LED%252C+Dimmable+Light+Bulb%252C+Warm+White+%25282700K%2529+E26+Base.jpg
Alphas
blackestvoid
Which part of the sentence was stated that only smart bulb are dimmable? Please learn to comprehend. There are so many dimmable bulbs but will require a dimmer socket to operate.
happy ?
again not all dimmable bulbs require dimmer socket
eg philips smart bulbs do not need dimmer socket as they themselves contain controller to dim which can connect to smart hubs or that you can control via apps
some bulbs are smart yet not dimmable
learn to express yourself properly so as not to mislead
let me help you rephrase
There are so many dimmable bulbs that may require a dimmer socket to operate.
tan_chs
Hi all, thanks for the insights. All suggestions welcome. The light I’m looking at is not a smart bulb but is dimmable. So far, I could only find touch panel dimmer in 1 gang variant but what would prefer is a more neater panel since I I have 4 sets of dimmable lights setup. Was thinking of just installing a 4 gang switch and set the dimmer function in app. Was think a dimmer relay might just do the trick
Alphas
happy ?
I find this strange when you want to correct the phrase when there wasn’t any issue. The determiner most is to represent something is true to a greater extent. The grammar of your sentence is very bad, and you should not mislead some bulbs are smart yet not dimmable.
blackestvoid
the way you phrase initially led me to believe you are not clear on what is dimmable, what is smart, what is bulb, what is socket
after my previous msg i start to give you benefit of doubt that you were merely having more of a problem of expressing yourself but you do know your stuff
now i am not sure exactly where you stand and what knowledge you have on the subject matter
proof of what i stated
who is misleading here?
my grammar may not be the best but at least i substantiate with proof so it is factual
ju5tme
Certified electrician doesn't do electrical work for switches without safety mark
I was thinking of changing all existing manual 3 gang switch to Smartul 3gang version (their 12.12 pricing ~12 after voucher), try to ask for certified electrician quote but was told he can't do as most of devices ship from China haven't been certified in Singapore, therefore not carrying safety mark.
Any certified electrician here that can confirm that it is against your license to install switches that have not been certified in Singapore?
bullfrog
I'm not a certified electrician but i can tell u that he cannot. Anything connected to Singapore power grid must be certified. Those using China products are at their own risk. If it burns the house down, ur home insurance probably won't cover.
If he changes it and something happens, he will get into trouble. However, there are those that don't care and still install. But that doesn't mean that cos a certified electrician installed, you are in the clear should something happen.
digitalhomes
Wow... I see a lot of different views here. My thoughts if you don’t mind is that all of us have different needs and budget when it comes to making our home Smart and be able to have a bit more productivity in our daily life’s and at the same time create that ambience of a hotel or resort feeling after a hard days at work or school, am I right?
Smart bulbs like Yeelight, lifx, Hue are all good but as the latter and most of those bulbs/lighting mentioned would need a hub to control them so in the case of your internet is down ( we are not talking about your home network down), you won’t be able to control them by the App as they are cloud dependent. Another set of downside is that it could be costly as a smart bulb etc when it’s down, the replacement fee could be quite high which would increase your maintenance fees over the years.
Going for a Smart keypad/ switch to work with any dimmeable lighting fixtures of your choice would always be ideal and there are controllers nowadays that can still control your lights from your App without the need of an internet.
I am more than happy to give advise but my apologies in advance if my reply is a bit tardy.
viix
Yeelight, Lifx and Hue are not cloud dependant.. They all have local control since forever.. maybe not if your system uses an API instead of custom control via special integration.
What about Control4, if the system requires modules to be added, or more complex automations to be added, does the user have the option to do it themselves? Or is it an something that requires a technician to come and therefore incur incremental cost?
Alphas
Many of these integrated smart home devices are proprietary. If you are tech savvy and like to diy, there are ESP8266 devices that can be flashed with open source firmware tasmota. Then all the device can be programmed with home assistant, openhab, etc. There are also smart devices that are already enabled with tasmota.
https://athom.aliexpress.com/
digitalhomes
Hi Viix,
Sorry my bad. Yes, without the Internet, those 3 x pure lighting vendors are able to work as they have their own controller. Meant to say that they won't work thru the Google Home App / Alexa App / Voice Control when the Internet is down.
Funny you mentioned about Control4 and I am not sure what are the folks thoughts on Control4, Savant, Crestron, Lutron etc as these commonly "Big 4" are mostly Dealer Installed systems which might have put off some of those who wanted to go for it but doesn't like the incurring cost of the labor charges of adding per module or changing or tweaking a bit on the systems programming etc. I can answer for Control4, Crestron and Lutron, users are allowed to do their own programming if they wish too but to be very honest, they would need to be taught on how to add modules, do the programming etc and these how-to videos etc are only available to dealers but if you are a tech-savvy person who loves gadgets and all, it should be a breeze for you to learn them thru any of the Dealers who are willng to impart their knowledge to you. So the answer to you is that yes, user can have access to the programming tools if the Dealer help you installed and give you access to it.
I am playing with an interesting tool as well. Not sure if you all heard about a company called Lightwaverf. It's a company based in UK and they make quite a decent Smart Dimmer Keypads and Smart 13AMP Sockets that works on 868Mhz RF frequency and it has bi-directional communication. The Smart Dimmer keypads works with dimmeable loads and best of all, no need neutral but the minimum watt of 10 watts is needed for the loads. It's a perfect solution for retrofit. :)
