Hmm, which smart switches are certified for use in SG?
i am also keen to replace some in my new place. How much will the switch and installation roughly cost?
I'm using Kyla Gen 2 switches. I got Aztech to install for me, $50 transport, $50 per switch point. Excludes cost of the switches.
Each switch comes with capacitor so that low-watt LED light can work with flicker.
It requires their proprietary Zigbee Smart Hub (right) to work. Running on WiFi, smaller and better than Gen 1 Hub (left)
Like all Smart Systems, the reliability is dependent on the uptime. Generally they work reliably.
They sponsored me one switch, hub, smart station, motion sensor, and I bought more switches and paid for installation.
Any questions, just send away. I know there are other cheaper systems out there but getting a branded system locally means I am assured of some level of technical support.
Wow... I see a lot of different views here. My thoughts if you don’t mind is that all of us have different needs and budget when it comes to making our home Smart and be able to have a bit more productivity in our daily life’s and at the same time create that ambience of a hotel or resort feeling after a hard days at work or school, am I right?
Smart bulbs like Yeelight, lifx, Hue are all good but as the latter and most of those bulbs/lighting mentioned would need a hub to control them so in the case of your internet is down ( we are not talking about your home network down), you won’t be able to control them by the App as they are cloud dependent. Another set of downside is that it could be costly as a smart bulb etc when it’s down, the replacement fee could be quite high which would increase your maintenance fees over the years.
Going for a Smart keypad/ switch to work with any dimmeable lighting fixtures of your choice would always be ideal and there are controllers nowadays that can still control your lights from your App without the need of an internet.
I am more than happy to give advise but my apologies in advance if my reply is a bit tardy.
I echo the same view. Two incidents happened recently cautioned me of converting more devices to smart.
Incident 1. Google network downed. My Google home mini just say, "There's a glitch" and unable to voice control any of my smart devices. Tuya smart however is working still.
Incident 2. M1 Internet downed. Again. Voice control failed.
More likely region setting issue. Switch to Chinese mainland and try again. If still doesn’t work, hope someone here can help you.
One of my 2021 resolutions, don’t buy Xiaomi and its affiliated products.
I'm using lots of xiaomi products. Region restrictions aren't that big an issue.GG
A lot of my new home products are xiaomi, thought all can easily integrate through xiao ai
My xiaomi roborock vacuum and air purifier are on SG servers. My light switches and curtain motors are set for mainland China servers.
I am using Home Assistant to bridge the gap so everything can be controlled with one UI. Even my smartthings, broadlink, sensibo, nanoleaf lights and harmony hub are managed with home assistant interface.
Posted from PCWX using SM-G988B
Google home assistant?
paiseh bro can share abit more on the home assisant thing ? is it an app or gateway ?
Not google.. Its this open source one.
https://www.home-assistant.io/
I didn't want to ruin the surprise laYou didn't warn them that home assistant is not easy. It is not that difficult too but you have a steep learning curve. The other good thing about home assistant is that it is running locally, so if your internet or Google Voice is down, you can still control the devices.
Besides, you and I can help them along if they run into trouble. The latest version of HA is easier to configure than the HA i struggled with almost 2 years ago. Most of the configuration is GUI based now. My current configuration file is very small.
Hmm, seems like this might be able to control the local Daikin iSmile air conditioners.
Noticed that eWeLink / Sonoff isn't listed, but Tuya is.
Its a kind of gateway i suppose. I'm running hassio at home. Hassio is a version of Home Assistant for raspberry pi.
Once you query out the tokens for your xiaomi devices/gateway, enter the tokens into the HA configuration file, HA will be able to communicate with them.
Here's a screenshot of my interface.
You can get the tokens of your xiaomi devices and gateway with this tool
https://github.com/PiotrMachowski/Xiaomi-cloud-tokens-extractor
