Mr BBFA
Hmm.. You have exposed trunking but there's some coating over it. Anyway, one way to pull a neutral wire there is to tap from the light bulb the light switch is connected to. I have no comment on the non neutral switches as there were some issues with them several years ago. Apparently its resolved now but i didn't go down that path. I suppose you can try first and if they fail after a few months, then go with neutral. But neutral is definitely better.
Yes. Get those 3 pin wireless adapters. Its easier than replacing the socket.
Posted from PCWX using SM-G988B
thank you! do you have any 3 pin wireless adapter to recommend?
also, for smart switch, let's say my led lighting i get those with dimming function and remote control. is there any way to control the dimming function of the lights via the app instead?
bullfrog
Too many out there. i suppose they all function similarly and many are not very expensive. Just pick up something from challenger la. I am using Samsung but that's only because i have a smartthings hub. I wouldn't recommend smartthings since there are cheaper alternatives. Also, its very hard to buy smarthings devices now. Won't be surprised if Samsung plans to discontinue their smarthings product line.
Regarding smart dimming lights. They are independent to the smart switches. As long power is available to the smart bulbs, you can dimm them, change colors or even off/on them via their app.
Mr BBFA
ahh cos i'm intending to get those normal led light which comes with remote control to change brightness
smart light quite pricey eh, and if the led inside spoils then gotta buy the whole thing cannot just change the led strips inside :s22:
thanks for your help!
Mr BBFA
Those should work fine as they are independent of smart switches too.
thanks!
lastly, anyone here got any electricians to recommend?
preferably affordable ones.
looked up on carousel got quite a few offering 35 - 50 dollars to change per light, in total i wana change about 8 ceiling lights to led kind... quite exp i feel
got shop quote me 35 for first light, subsequent 12 but must buy light from them
also wana change the switch boxes in my house too :s22:
pustefix
Questions, for hassio
1. Using ZHA, z2mqtt??
2. SSD or SD card?
I am using z2mqtt, hassio on intel NUC, so SSD. For Raspberry Pi and SD card, the cons are potential SD card failure and the bootup time is slower. I've upgraded from Pi to NUC so that I don't have to worry about SD card failure.
bullfrog
The cons are valid. In fact, after reading your post, I downloaded the hassio vmdk and configured it for virtualbox. Restored my snapshot backup and with a little configuration tweaks, everything works. :)
My PC is on all the time with some vms running on an attached RAID1 SSD.. Probably safer to use that instead of an SDCard. Dunno why I didn't think of doing that before :s22:
Alphas
There are high endurance SDcard, so it’s still an option. NUC would consume more power than raspberry pi if it was used as the server.
rwheatla
IR Hub advice
I’m looking for some advice
Have recently obtained a google home speaker and connected up a couple of Xiaomi/Yeelights. I would now like to use it to connect my ceiling fan and AC units so Im looking to get a IR hub/blaster.
I’m looking at some advice regarding which device to buy
Xiaomi MI Remomyte – doesn’t work with Google Home
Harmony Hub, seems to be a good device but can it work the Singtel TV box?
Broadlink 4th Gen. Not sure if I need the RF version or which devices use RF.
Any suggestions/advice based on 2021 products would be much appreciated.
bullfrog
I'm looking for some advice
I'm looking at some advice regarding which device to buy
Xiaomi MI Remomyte doesn't work with Google Home
Your fan remote use IR or RF? Usually from the remote can guess if you need an RF/IR blaster. Skip harmony hub. Its only useful if you have a big area where you need multiple IR emitters to send the same signal simultaneously. . Like a big patio with 3 ceiling fans (for example)
If you only need IR, you might want to consider this. Someone shared in this thread many pages back. Looks interesting. I'm not using it but i would consider if i didn't have an existing solution and wasn't interested in tinkering around with HA. .
https://h4sh.automate.asia/products/...BoC6XwQAvD_BwE
More videos on it here
https://www.threecubes.com.sg/produc...d0e7c7c4&_ss=r
Besaid
Is it possible to convert hue or nanoleaf LED strips to connect directly into the main circuit like normal light bulbs, instead of using our 3 prong power socket?
bullfrog
Nanoleaf uses DC current so probably not as there needs to be a conversion from AC to DC to power it. Whatever you try, there will be a small brick to do the current conversion.
Reading from another forum, it appears that there are some that use this as a converter to drive the Hue. However, as I am not a expert, I am not sure if it can be replicated for the Nanoleaf.
I am more interested in the Nanoleaf, as its way cheaper, supports Homekit and Thread.
rwheatla
Many thanks.
Just checked and I think the fan is RF controlled. Any other suggestions?
bullfrog
Many thanks.
Broadlink then. If broadlink cannot control, (fan not using the standard frequencies) you might be out of luck.
bullfrog
Yeah, i'm using nanoleaf too. Very simple to add it into home assistant too. One of the reasons I bought it.
That’s great. Any comments on how to convert the led strips to be connected using switches rather than sockets?
bullfrog
That's great. Any comments on how to convert the led strips to be connected using switches rather than sockets?
Sorry can't help you there. Sockets work fine for my setup as everything is neatly tucked away.
kenho_23
I am sorry if someone asked this before. I have a BTO that complete in 2022. Just wanted to know if neutral wire already exists in the wall switch?
