waterfoe
Logitech Harmony is a good option if you DIY everything.....
I do have the Harmony universal remote as well, but because all command have to go through the logitech cloud than communicate with my insteon cloud before the action is executed so there is some time lag.....
If you use the remote purely for equipment control, it quite responsive..... But if you create an activity to switch on the TV and change your lighting scene, you will still achieve the end result, but lag.
Not sure about your experience, but that is what i notice....
no need crestron ba. logitech harmony will do.
neutral wiring, there's a way to do it without having to rewire whole house.
bullfrog
I personally will still go with Harmony over RM Pro cos both devices have reliance on their company's respective clouds.
My confidence in China products are low as their cloud might go offline anytime. With harmony, Logitech should have better responsibility towards her customers.
nakitaro
when you are connecting to the hub remotely, there will be delay or lag.
when you are connected to the same local network, the delay is not so much noticeable.
do check out logitech smart keyboard for the hub for anyone with htpc in living room, consoles and boxes.
waterfoe
All are connected on the same network.....
But still there is still delay.... Such system are good for simple home automation..... If you want to include more complex expression, such system will not be so ideal....
waterfoe
I agree with you.....
Price wise no doubt the china brands are very cheap..... But imagine when u need the system to perform at the critical moment it fails you.....
nakitaro
true. atm protocols are preset, no way to customize it.
the delay is abt 500ms plus minus
usually much less
waterfoe
With IFTTT, you can have 1 trigger event and you cant have the "AND", "OR", "ELSE" expression.....
I use it with Stringify, but it doesnt seem to be very reliable.....
Afterall, Stringify, insteon, logitech all are cloud based.... So it not that responsive..... and i believe that is the best option in the market....
Now i know why some of the home automation system are more expensive than the others.... lol
nakitaro
huh? logitech is cloud based when you connect to it remotely.
i don't see your problem totally. can you describe what is slow at a granular level?
mouse input from logitech remote?
waterfoe
If you only uses logitech harmony to control your AV equipments than it doesnt matter if u have internet access or not....
If you integrate them with your home automation system..... Than it going through the cloud....
That is my understanding..... i might be wrong..... cos i remembered there is once when my internet connection was done and some of the lighting doesnt seem to work....
nakitaro
erm, i also hv lightings to control, including aircon.
whereas whether or not internet affects locally, i can't ans that as of now. perhaps some of your lightings require internet connection?
waterfoe
My home automation actually running on cloud.....
That why it goes through 2 different cloud to execute the command.
waterfoe
Is Logitech Harmony running on cloud, i believe the below url should explain more....
arstechnica.com/gadgets/2017/11/logitech-to-shut-down-service-and-support-for-harmony-link-devices-in-2018/
icic in that case, nothing to do with logitech then
nakitaro
waterfoe
My Bose theatre system is running on RF..... So i think there shouldnt be any issue....
Best to double check on the list of support product on logitech website
Can harmony hub control RF devices? or only IR, wireless and Bluetooth
hAiZzZ86
thanks for the reply. thats why im confused when people tell me it can control RF devices (433mhz)
i couldnt find any information on RF.
Control your devices behind closed cabinets and doors with IR, Wi-Fi and Bluetooth® wireless.
https://www.logitech.com/en-us/product/harmony-hub?crid=60
