XcoldstarX
Thought so, thanks. I have neutral wiring but already bought all my switches, maybe in future down the line can consider the dimming.
The dial switch I shared has a remote variant so you can use the remote to control the wall installed dial switch.
ferbulous
I have something similar for my water heater. Show up on the tuya smart app.
All was working well until I went to update the firmware of the switch
now the switch is always offline when my
Mobile is not near the switch. Have to remove and re-pair the switch for it to work. It stays paired for a day then then goes offline
Minor annoyance since I set it on timer to turn on and off.
have you encountered similar problems with yours?
Same issue here, you got the touch switch type?
Got annoyed and decided to install this firmware, no disconnection since then
https://github.com/openshwprojects/OpenBK7231T_App
idunwantaname
Hi Alex, would like to ask you about Aqara hub. I am currently using M2 hub global version, and successfully paired all the switches on Aqara app under "Others" server. Problem arises when I tried to connect Alexa as my voice assistant. All my 3 gang switches can't seem to be added.
Was really toying with the idea of having another Aqara hub m1s to control the 3 gang switches, which hopefully will get discovered by Alexa voice assistant.
Just to check, which hub are you using for your home? And connected to which server?
Thanks so much!
Read HWZ Forum Rules!
Did you manage to resolve this problem with the 3 gang switches? I have a similar problem too.
kujuta
Purchased aqara G3 camera hub from taobao. Will be using a aqara m2 hub(global version). Can any kind soul advise if the g3 can be connected to the m2 hub, then Google home? Thanks alot!
t258jgn
Just install Somfy motorised curtain with RTS. Then use bond hub to control.
Though you paid a premium, you get the build quality of Somfy with 5 years warranty coverage for their motor. They are the trusted brand in motorised curtains and blinds.​
I looked at Somfy website I catch no balls :s22:
What is DCT WT RTS?
I just want simple connection with Google Home & remote + Wired AC Power
Which one I should get?
deodorant
Hi guys, what are the best options for ziptrak outdoor blinds into HomeKit (the rest of the house is aqara stuff)?
i saw that aqara has a smart roller driver but not sure if it can be used/by any of the local ziptrak suppliers.
flikmy
You don't need to connect G3 camera to the m2 hub. The G3 is a hub in itself (connects to your network via wifi).
Your other aqara devices (sensors/switches) need to connect to a hub as they are connecting via zig bee.
The only problem you might have is whether you can connect to the G3 hub using your global aqara account. Not tried it myself as I've tried to buy global hubs (mixed with china & global based switches/sensors).
hunterhelm
Anyone here using hubitat managed to connect their aqara products to it yet? I thinking is it possible to connect an aqara hub to it for e.g. Aqara G3
XcoldstarX
Please refer to image below I got from Aqara:
Vodkilla
Hi guys, any recommendations on smart switches for use with Smart Things? I heard Aqara switches not easy to integrate/not native is that true?
deodorant
Thanks, yah I’m thinking of using aqara stuff for my curtains, but the problem is more the outdoor roller blinds. As far as I can tell there are no ziptrak-type blinds that natively integrate into HomeKit, my google power tells me the only option is for RF blasters into home assistant or home bridge first and then that will go into HomeKit … hmmm.
kylnxa
Any recommendations for square ceiling lamps that can be used with Home Assistant?
Something like IKEA Floalt or Yeelight Jade 500S etc.
batniss
true. if anyone tell u is easy is not telling you the entire truth.
DaFeiLong
Hi gurus. I bought an aqara M2 hub and an aqara wireless mini switch. I successfully paired them together but I was wondering if it can be set up as a doorbell. Any thoughts/suggestions?
