wacko
Hello to all gurus, hope you guys can help me out here...
I recently bought 2x smatrul 2 gang touch switch
(shopee.sg/SMATRUL-WiFi-Smart-Wall-Switch-433RF-Google-Home-Amazon-Alexa-tmall-genie(single-fire-line-neutral-and-fire-line)-i.233192871.7739225204?sp_atk=d96343ee-3e17-43cc-8956-267f41a06f19&xptdk=d96343ee-3e17-43cc-8956-267f41a06f19)
I thought I would be able to make it 2 way for 2 of my lights.. but my electrician say cannot be done because I do not have neutral wire... if really want to i need to rewire with neutral wire..
Does any one have any advice or tips to make it 2 way? or is it not possible?
smart switches don't work in a 2-way circuit in the traditional sense. you will need one side to be a regular smart switch, and the other side a remote switch that controls the first smart switch.
TanKianW
Aqara Curtain E1
A custom soldered PIR sensor that is better than Aqara FP1?
delvonche
My existing is a normal switch, 2 gang 2 way.. no neutral wire… I have wifi connected… just wondering if
thanks for the suggestion! Will try it out and post here to update all :)
It works!!! Thanks for the diagram! Made things so much easier!
ferbulous
Aqara Curtain E1
Have you tried adding tinfoil cap to the dfrobot radar sensor just like a fellow user here did for aqara fp1?
Doesn’t make for useful static sensor if it still detects ceiling fans by default
TanKianW
Actually there is no reason for me to use the Aqara sensor. I am sharing the information (not even promoting) for those interested. To be honest, I think anyone who purchased a tech product without extensive research, understanding the technology and conduct some sample self-testing, immediately procure a large number of it, thinking it will work for his use case….is taking a huge risk and not really making a well thought-out move (Eg. the fb guy).
Personally, I am still using the light and motion sensor from Philips Hue and it works really well for my use case for the past 5-6 years. Which I also use for triggering some custom automation on HA. In my view, i find a “wired” sensor not practical for my use case and a hassle to find a power point and hide the cabling. I also prefer not fixing something that is not broken.
airzound
i recently purchased a zipblind that is motorised; company name is Legate.
They have their own app, the interface looks exactly like Smart Life app. Once I go through the in-app settings to connect to my wifi, i am able to control the opening/closing from phone. I also do have a RF controller provided by them to control the blind.
Legate's helpdesk told me that they only support Google Home integration. And true enough, i could find the Legate Smart Home app when i add new device within Google Home.
However, I am using Alexa, and i couldn't find the Legate Smart Home app within Alexa's Skills & Games. This was also confirmed by their helpdesk that they do not support Alexa.
Question is:
Because I am using Alexa throughout my house, is there a way to connect this Legate Smart Home to Alexa?
I have tried using IFTTT, but I was not able to use Google Home / Google Assistance as the end point action (Then that).
I am open to getting a Google Home device but i still wish to use Alexa's command throughout the house.
Some advice please!
lvlaTr1X
Recently noticed something weird for Aqara D1.
I am using a 3-gang switch with only 1 physical wiring connected and the other 2 as virtual switch to control my kitchen toilet light and service yard light.
My automation is such that if there's a single click for the button 2 or 3, the toilet light or service yard light will turn on/off. I noticed that sometime the log will turn off the switch but doesn't record it as a single click, hence the automation doesn't run and the toilet or service yard light will stay on. Is this normal?
kun1he2
Strange, had a network outage just now - had to restart my M1 ONT and Google Nest Wifi Router.
All smart switches back online - but my two Tuya Wifi Smart Power Strips lost all the names of the individual switches, i.e. reset to Switch 1 to 5.
Also, although able to control the switches, the ON/OFF state is not remembered in the App, i.e. restart the Smart Life App, and everything shows as off even though some of the switches are turned on.
Anyone else encountering the same? Only seems to be affecting the power strips.
deodorant
Just a heads up for anyone thinking of hooting stuff from souky (Lazada/shoppee) for 8.8 — I have a small order with his shop pending for 3 weeks liao still not shipped & being ignored when I ask when it will be shipped.
VodkaPear
Weird, I have no problem ordering with this vendor in both Lazada/Shopee. Maybe request refund?
lance88
Same I bought from before and no issue. But personally their price is on a higher side if you are getting aqara stuff
yamashita
Moderator
Moderator
No issue for the Aqara product I bought last week from Souky. Received my item the next day after order was placed.
lycanboy
Hi guys, is anyone using ZigBee plugs that can work with Aqara hub?
I am trying to trigger my appliances by using wireless switch routine.
I am running Google home plus Aqara m2 hub global. Thanks!
deodorant
Strange ah why only mine stuck? Annoyingly I message them also no reply. Anyway if the rest of you have no problems then maybe just mine slipped through the cracks or something.
wacko
Aqara is a closed system, so you can only add an Aqara smart plug into the Aqara hub, and there are no UK style Aqara smart plug today available. Alternatively you can get another brand WiFi smart plug, e.g. TP Link Tapo, which can be integrated into Google Home, and use voice commands to control it.
batniss
Recently Laz keeps losing my items.
Although they keep refunding but still annoying.
katty91
I buy from them cause they know their stuff and give good advice.
Can try ask Lazada cancel that’s the fastest. I also bought something from another seller they shipped but courier lost package the status just stuck forever.
ZigguratZ
Any Tuya smart switch butties encountered this issue before?
Had a blackout for the whole estate, after the power restored, one of the smart switch kept switching on and off by itself. Even after resetting it, the same issue will appear.
Have to off and on the DB box to stop it. Is the switch faulty due to the blackout?
