batniss
Thanks. I now see the wisdom in such setup. I was stuck with either this or that and not both.
Need to find a smart fan with strong wind. A nice looking white one and doesn’t blow my wallet.
PO ECO series not bad.
ferbulous
For budget friendly edition, just grab any normal ceiling fan and install ifan04
ferbulous
what is the best way to implement nightlight for baby ah?
no need very bright, I got spare power sockets ( not smart ).
so perhaps
if baby around on this light between 8pm till 6am. Tks
something like this ah?
what you all think of this ah?
https://shopee.sg/Yeelight-Plug-in-Sensor-Night-Light-i.111663909.5430065985
this one is wifi? for HA is no need additional hardware rite? wifi is built in rite?
thretiredDad
How to know if a smart device
is china or global version?
my friend say just by seeing if it support google home
really?
deodorant
really?
Aqara? If you buy from local sellers they will say the version type in the listing. If you buy from like taobao then CN version.
ferbulous
Alamak! All Chinese. I D7 in that :LOL:
Thanks. Didn’t know such device exist. Must buka fan and install. Swing function not crucial for me.
Seems like all using tmall. Not sure about the integration with google assistant/alexa
I’d recommend the second link because it’s got an esp chip that you can still flash custom firmware.
Kitaro9202
Just got my smart switch and i notice that my surface box can't fit it. Went on to buy the surface box.
Any one know use what to cut the surface box to let the wire go inside the box?
shinoku2
Anyone managed to successfully pair aqara h1 non neutral china version switches with m1s hub china version? I tired to pair the hub successfully but couldn't find the h1 switches or when I added it is under zigbee child devices where I can't even connect the switches
1 device can have several entities
Example if it’s 3 gang switch, then got 3 entities (light switch 1 & 2, fan switch 3).
If you turn on by device, then it will toggle all 3 entities
You can edit the area with the pencil icon next to device name
Silly question again..
First pic is device screen
When I double click dimmer
The Controls I named it as telly light. Is this correct? For this example 1 device 1 dimmer.
What about when I enhance using Alexa.. Do I say Turn on Dimmer Light or telly light.
A bit confused about this.
Side track..,
What is the Alarm Type and Over-load status? Are these useful?
Thanks
ferbulous
Side track..,
Thanks
with alexa, it's usually the entity name
Not sure about those not visible entities
