TanKianW
Got their app to work and use wifi?
So let say I got 4 aircon at home i need buy 4 sensibo?
Yes, works on wifi. Power over micro-USB.
It works the same as your remote control. Since all your a/c works on the same IR signal, it could activate multiple a/c that is close together within the IR firing range.
Logically, you want individual hub to only work with the a/c in a particular room. Btw, it works with your Google Home and Alexa too. For Google Home, you can just say “Hey Google, turn on the AC.” If you set your Google Home hub in the same room (you are in) as the Sensibo hub, it will turn on the ac for that room. You can also control your a/c temp by saying “Hey Google, set the AC to 24 degrees.” Personally, I use Google to control my a/c more than using HA dashboard. I mainly use HA for triggering the AC automations. (Eg. Switching off the A/C when no one at home, switched on the A/C for pre-cooling when I am entering the geofencing set as my home after work, etc)​
Kitaro9202
Ok interesting shall check it out but the price is kinda of steep
ferbulous
Bro, I buy all of these still cheaper than my ONE pc Aeotec Motion sensor which is 'broken'.
Hope I got the right stuff . Thanks
Good enough, add extra stuff like temp/humidity sensor, light sensor
yeah, cheaper and not region based like z-wave that’s for sure
thretiredDad
Bought fingerbot plus
able to use with Tuya app
but google home or Alexa
is always offline
any quick solution?
thretiredDad
Any good smart power socket
to schedule off and on time
for my router daily
and also manual reset
each time i manual off
the router is off
no wifi
cannot turn back on
iCubes
for my router daily
the router is off
no wifi
cannot turn back on
You can get a smart plug - the ones by TP-link Kasa is good
TanKianW
When I see this type my heart miss a bit, those like half half supported and if it's expensive really have to triple confirm if it works. Paiseh I newbie
These are for the tinkerers. You should possess some electrical and electronic knowledge/background before embarking on all these. And be mentally prepared of voiding your appliance warranty when you screw up....
If you are not a tinkerer, I advise to avoid the hassle and risk.
Don't get me wrong, ESPHome is a good project with HA support. But not for the faint of heart.
Btw, your round up album. Still got the CD. It's good 👍
Vodkilla
What is your opinion? Is it better to have smart switches with dumb lights or smart lights with normal switches? Is it a good idea to have both switches and lights smart capable? The only pro I can think of with smart light/normal switch is colourful light. Any difference in electricity usage in either setup?
depends on use case... but generally smart lights better because can control brightness and temperature.
downside is visitors may turn off your light switches :D
personally I use smart switches (convert to always on and use the buttons for triggers) + Smart lights for best of both worlds (but added cost)
ferbulous
If you are in your Living room
router in your bedroom
the router is down and require reboot
you wait for it to reboot by itself?
When it's down, you can't access the router at all?
Is that why you still have to reboot by power cycling it?
I'd also recommend getting a tasmota plug (athom), and add this rule (copy and paste to the console), this pings the router and automatically turns off then on if the router's down
Code:
Rule1  ON Time#Minute|5 DO backlog Ping4 192.168.1.10 ENDON  ON Ping#192.168.1.10#Success==0 DO Backlog Power1 0; Delay 10; Power1 1; ENDON Rule1 1
Replace 5 with time interval you need to check, and 192.168.1.10 with your router ip address
