katty91
E1 is in singapore now?
I have some (at least 10 pieces) brand new Aqara E1 double switch (with neutral wire) to give away. I ended up re-buying without neutral wire as I didn't want to re-wire my entire home to accommodate them. PM me for details.
Luvmusic77
Hi, is the Aqara E1 still available? let me know the details as I cannot PM as new member
thretiredDad
Hi all smart brother
Recently I bought a zigbee only button
I’m using wifi/zigbee gateway
tried to use smartlife to detect but can’t
asked the lazada store
he said just add from the gateway
not from app
is there a button to press on the gateway?
Shadowlite
not from app
Go in smartlife app and click on the gateway. Should have option for you to search for zigbee device
Nystalia1990
Hello, I am considering to change to smart switches. I have considered Aqara but it seems they don't have 20A heater switch. I am assuming that normal light switches does not comes with neutral wire by default. Is it possible to wire up smart switch for BTO 2 way living room switch? Any recommendations of 20A heater switch? I trying to have the same look for all the switches.
ferbulous
Do you plan to use homekit with aqara?
There’s homekit 20a switches at shopee
otherwise:
Aqara switch -> contactor -> ac/water heater
To keep the aesthetics like some people have done
is your 2 way wiring like this?
Nystalia1990
otherwise:
I haven't plan actually. Most probably will be Google Home. HomeKit is fine too. I also considered Tuya switches as well.
I not really sure how is the wiring, But should be the same as what u had drawn. Mine is a 2 gang 2 way switch as default.
ferbulous
For the 2 way wiring, if you don’t want to add extra new wires.
You can use this trick, it allows to install the module (like aqara 2 way relay) at the light fixture
TanKianW
Alex Teo’s (from Singapore) recent smart home YT video. This should be more user friendly for most home owners out there integrating their smart home devices with Google Home. He recommends using Tuya during this update.
Arc~en~Ciel
Anybody using Moes Zigbee smart switch? If wire up smart switch with other non smart switch in same circuit, have you encountered those lights linked to the smart switch will flash once when the non smart switch is switched on? It happens to me intermittently even though the smart switches are linked to neutral wire.
googoogaga
otherwise:
I am also using all aqara switches and had decided to get these heater switches from Lerlink which looks somewhat like aqara. However your solution involving using aqara sounds more interesting to me.
May I know what's a contactor? Will all electricians know how to do it? Also can I connect this to one of the switches in a 2/3 gang aqara h1 or does it need to be a 1 gang aqara only?
googoogaga
I am looking to use following automation in bathroom
- Switch on exhaust fan and lights in bathroom when the bathroom is occupied.
- When the person leaves the lights should switch off but exhaust fan should run until the humidity level drops to a particular point.
I am thinking I need to connect the exhaust fan to one switch and lights to another switch and then use a motion sensor and a humidity sensor to do this. Will a Tuya ZigBee solution with AliExpress tuya devices work for this? Anything to watch out for? Like sensor sensitivity etc? Any recommendation for the sensors. I am thinking of getting the Moes ZigBee glass switches.
deodorant
Motion sensor won’t work, you need those human presence sensor. From personal experience motion sensors don’t work in bathrooms cos there are times you are in but don’t move enough to trigger it. Like when sitting on the throne.
ferbulous
It’s a device that isolate the load from the switch driving it.
just have it wired between the smart switch & water heater
Technically you can, just that normally people have 1 gang switch for the water heater/ac
Usually I’d recommend mmwave sensors but they’re too sensitive to fans.
Add more motion sensors to cover all the angles
edixian
Experts here, if renovating the house and intend to have some home automation, how should i go about it. The electrician wil only do rewiring how this automation come into the picture? Im a noob on this
