ryouma
I bought Aqara D1 from Taobao. Realize they can't work with M2 Hub due to region lock. But I managed to pair it directly to my Smartthings Hub using Groovy custom DTH. However, the lag is often times noticeable. I am trying to figure out how to use Edge driver instead to pair D1 to my smartthings hub. So far no luck.
All in all, it's a little troublesome if you get China D1 switch. I think Aqara will soon rollout Matter for all it's products. So in the future, it might be easier to directly link D1 switches to Smartthings Hub.
Oh that's odd. I thought from what i gathered around, switches dont matter. It's the hub that has to be global version.. ?
Kegler
Hi all
Anyone tried aqara h1 decouple mode?
Let's say 3 gang switch...can I connect the wiring for 2 lights.... leaving the 3rd unconnect for decouple as wireless
hjoshua
has anyone tried the “bluff method” to pair an aqara curtain with Xiaomi gateway 3 successfully?
this is the seller i bought from. I dun think he is the only one selling this version. Doubt there's any difference between the numerous sellers on lazada/shopee.
Take note, aqara D1 switch pairing to xiami gateway 3 is not "officially" supported (meaning it will not appear automatically like those officially supported devices once power on).
I got it to work by "bluffing" the mi home app that I am pairing another device in the list such as, Mi Wireless Switch. It's a trial and error that it managed to work, but I can un-pair and re-pair and it still works, so I guess it should not be one time lucky only.
In fact, I paired my aqara motion sensor, aqara magic cube, aqara window/door sensor, aqara mini switch all via this "bluff" method. As long you can get the child device to go into pairing mode, then you can trick the mi home app to let you pair to mi home gateway 3 already.
Btw, I am waiting for Aqara E1 switch to arrive from taobao. I bought E1 because I am not satisfied with the tactile feedback of my D1 switch. (duno is my D1 switch button faulty though)
I mostly used aqara sensors and feels like their battery last forever
is it for your zigbee devices if accidentally unpaired?
Hi,
I think the battery is low again. I think it's about 1 to 2 months only
I placed it in the room power is 100% then when I put it beside the RPI it dropped to 10%. LQI is sub 50.
If put beside RPI is 150 LQI.
So what would be the action that I should take? Try with your Aqara? Can sic? Thanks
ryouma
anyone has a guide to how to do 2-way aqara d1 switches?
Read it requires a hardwired D1 switch and one wireless D1 switch. How does the wiring go though ?
ZigguratZ
Hi, using a tuya smart switch as my master switch for my TV and router .. however the switch will sometimes auto off by itself ... Any bros here encountered the same issue?
Not sure what can I do to troubleshoot it ..
deodorant
Don’t think of it as a normal 2 way switch. Think of it as you have 1 switch (wired) and another wireless one that you set up as a remote control for the wired switch.
Note that you can also use other aqara switches extra rocker as a remote, for eg my house has several 2-gang switches that are only wired to 1 light, and the 2nd gang I use as remote control for other switches. (But I’m not sure if non neutral wiring switch can work like this, mine are neutral wiring version.).
ZigguratZ
No one uses it for multiple appliances?
ferbulous
Hi,
Is that just one sensor or multiple sensors also battery depleted too fast?
ryouma
yes mine are all non-neutrals. Wondering if wireless switches can act as 'remote control'.
Also, i assume the wireless mini switch would work similar to the wireless D1 switch ?
sword28
Yes worked perfectly with non-neutral D1 switches.
Just recently did my reno with whole house non-neutral D1 switches, and purposely getting some 2 or 3 gang to use the extra rocker as wireless switch for 2-way control or remote control to activate scene in homekit.
