IcYFl4mEz
For the contact sensor, just make sure it’s got a reed switch. I’ve seen some people posted door sensor that doesn’t have reed switch inside. If you plan to hook up pressure strips to it
Now that i think of it, contact sensor might not work for toilet.
lets say i open the door, it lights up. but sometimes you need to close the door to use the toilet.
any good recommendation of mmwave sensor/PIR that works with smart life?
ferbulous
Any tuya mmwave sensor gets the job done.
If got ventilation fan, remember to turn it off manually because it gives off false presence detection
IcYFl4mEz
the one u r using is youpin/xiaomi right? which wont work with smart life
Rusty89
Can i check is it possible to pair Aqara door lock on 2 different mobile devices on the Aqara app?
wacko
impractical in a toilet situation, as all mmwave sensors today requires USB power.
Alphas
ferbulous
IcYFl4mEz
The detection is acceptable, but design wise
It’s way too big and blocky, i thought it was the same size like fp1 but it’s like 3x bigger (didn’t check the dimensions)
People who come by to your house probably gonna notice a big red traffic light box in plain site.
Does both runs on battery? I see the one you shared , like wired ?
pustefix
I've been using door/contact and motion sensor for toilet, working fine for years now. Basically automation is like this:
  • When motion is detected, turn on light
  • When door is closed, don't turn off light
  • When door is opened, turn off light
The only corner case is when door is opened but motion is not turn off yet, next guy in may not trigger light on. In that case, just manually toggle the switch. I am using Home Assistant, don't know if other app can do these automations.
IcYFl4mEz
this is a good idea, but if inside MBR , if you on aircon, u will need to close the toilet door.
or you setting is, all must be fulfilled ?
pustefix
If you close the door and the motion sensor is activated, just turn off the light before door is closed.
crashed
Apple Homepod and Homepod Mini are both available in Singapore started 6 April :)
And Apple store SG started selling Aqara and other smarthome accessories.
flikmy
Indeed. Pricing isn't too bad either with homepod mini at $139.
Hopefully prices start coming down with apple store sales on lazada and shopee. :)
Surprising that it's taken so long for apple to bring the homepod to Singapore.
Choobie
Hi for those using Moe's smart switch any advice on which hub to get?
Looking to run with gh as well as Z wave Yale smart lock.
Tia!
crashed
yeah close to what US is pricing it at. very fair.
comwhizcjscjs
Looking to set up a smart home with Aqara switches - but just wanted to check if the switches are Region locked?
Anyone has experience with the H1 Pro (China ver - but has different colour options) vs H1 (Singapore ver) switches - any issues linking to SG Aqara M2 hub?
Endless09
I have Google Home setup as my smart home automation currently. With the introduction of Apple HomePod in Singapore, can both Apple and Google work together without any bridge/hub? I did my research and noticed I need a third party bridge to make both ecosystems work. Any advice ?
