impractical in a toilet situation, as all mmwave sensors today requires USB power.
I would suggest letting the TS decide based on his individual cases.
I have also created an automated toilet system with motion and humidity sensors and a ventilation fan. Everything was hardwired, eliminating the need for battery replacements. If the ventilation fan is intended, external power in the ceiling must be a prerequisite.
I designed everything from calculating the air change requirement and fan sizing to laser-cutting the mounting board material and completing the installation. Since the motor involved is a small fan motor, some protection from back current is required when the fan stops.
Make your toilet smart and user breathe easily, mmWave motion detection to detect human presence and keep ventilation on. The humidity sensor will trigger the fan to run when it reaches a certain value. When there is no motion in the toilet for an extended period, the fan will run for a short time to clear stale air, and there are many other features available.
