elvintay07
Suspended
I realised Aqara Singapore doesn’t sell this control panel. With this control panel, I don’t think you will need a hub. This can be the hard wired centre console. Tio bo experts?
【淘宝】https://m.tb.cn/h.UFjBIri?tk=3jMNdMZEsHC CZ0001 「Aqara绿米智能开关S1E智能家居控制面板HomeKit全面触屏妙控开关」
点击链接直接打开 或者 淘宝搜索直接打开
elvintay07
Suspended
Anyone know how easy is it to add neutral wire for new condo? A few electricians say they don’t do
spvnnn
Hi there need some help. Has anyone used non neutral aqara H1 switches with smart fan? Specifically it’s PO brand fans. Any issues?
also, what about regular non-smart ceiling fans? I was told by salesperson that non-neutral aqara H1 not suitable for ceiling fans…?
How are most of you all connecting up ceiling fans?
elvintay07
Suspended
Most ceiling fans are dumb right? No need neutral. I need neutral because some control panel need a neutral.
Tucksoon
I used the Broadlink RM4 Pro. My existing ceiling fan has a RF remote. The RM4 Pro works ok with Voice Assistance too.
TanKianW
**Smart light with Dumb Switch, Dumb light with Smart Switch, Smart light with Smart Switch.**
I will not recommend the use of smart switch with smart light unless you really have very good reasons to do so. As for choosing between smart switch or smart lights? Both have their pros and cons, and I recommend not sticking to just one solution. I deploy both smart switches and smart lights at different zones of my house, you get the best of both worlds.​
Revolution
Not sure on the non neutral switch.
but currently I’m in the midst of settling electrical works of my new home, was told every additional neutral added to the power point will cost me $60
and if I want to set up a smart home, it is advisable to have neutral setup as those non neutral ones tend to cause flickering based on his experience with his other clients.
YMMV.
mizumi
Guys, newbie here. I’m trying to control my AC remotely, as well as setup automation based on temp range/humidity, and maybe geofencing (optional). Any suggestions on IR emitter that integrates well with wireless temp/humidity sensors?
I’m using Google Nest Wifi currently. Is Broadlink RM4 mini IR emitter a good place to start? Found some users when researching mentioning abt pairing issues with Google Wifi due to the 2.4GHz band only issue.
TenOhmOnly
Hi!
Since you old bird here... do you have recommended touch switch (zigbee) with routing feature, I don't endpoint devices.
TanKianW
Hi!
Not the old bird here. Just earlier to the smart home/automation game.
Touch one I never use before. Clicky ones, I tried near.sg ZB heater switch with neutral, it has routing function. Another cheapo way is deploy Sonoff S26 smart plug or some no brand smart plugs which also act as routers. Other brands, you will have to research on the HA forum. If unsure, buy a few and test it out on your own. Though a bit wasteful, in my experience, some of the better routers are coordinators flashed as routers (using custom Tasmota firmware), such as the Sonoff ZB Bridge/Pro.
Sometimes you can find info on the Smart Home ZB guru Blakadder's website too: HERE
Also the person behind the ZB compatibility Repository too: HERE
HA forum discussion check out: HERE
near.sg heater switch which could act as router (over ZB2MQTT):
Sonoff S26 smart plug which could act as router (over ZHA):
lamerena
For neutral wires is it for lighting point where you want to install the smart switch or is it for all the power socket?
Revolution
Hi all,
I am in abit of limbo here and would like to seek advice here.
I’m looking to automate some parts of my home
1) lights
2) curtains in living and MBR
3) A/C for living room 2 units / mbr 1 unit
4) main door lock + door bell
I consulted a local firm who deals with Control4 and I was happy with what it can do, but I guess it’s like buying a 911.
Lives up to expectation but beyond my budget.
So I am looking to go with Google Home Assistant to manage my costs and work within.
My question,
For living room lighting controls are there
“Scene preset” lighting switches, where I can select say up to 4 presets.
because I have guests over and it will be easier if they are turning on or off the lights. But I also would like to be able to control via google home assistant app.
for the other devices like curtains and A/C control, can I go with Tuya and IR blaster to control via home assistant?
Not sure if I missed out anything here but your advice will surely help.
TanKianW
Going down the route of HA......is not for everyone. You want to save on cost, you need to spend more time reading up. I will say it upfront......lots of reading and watching online tutorials, and maybe accompanying with some sleepless nights. The HA journey can be both frustrating and satisfying, subject to your level of tech savvy-ness and understanding of both software/hardware. Understanding "networking" will likely make the whole process much smoother too.
You can have a read up HERE.
And if you think you are comfortable with it. It can almost do anything you had in mind.
ferbulous
Yes, I’m using the same device + tasmota irhvac integration
It also updates the ac status if someone used the physical remote.
There’s zigbee scene switches you could use for that. I haven’t tried any wired scene switches but they are available
Revolution
Hi TanKianW,
I did a bad typo
I mean google home.
yes I feel HA is abit too advanced for me when I read your guide 2 weeks back.
not from a IT related line and I must say scripting etc might be abit tough at my current understanding.
I’ve been spending time on reading and watching tutorials big thanks to YouTube.
but my automation needs are not so high as I’m new to the automation.
for starters I narrowed down to
Motorised tracks for curtains
A/C using Ir blasters and I hope to control my ziptracks as well.
for lights I just need app control and scene buttons
would there be any 4 scene button switches recommended?
Revolution
I saw those 4 squares zig bee switches on shoppee from Moes, I find them aesthetically pleasing and useful to place on my dining area or coffee table …
im ok to replace batteries but was told some zigbee devices “don’t talk well” to certain hubs?
