yang_nastyman
- Nov 25, 2011
Deciding between aqara or tuya system for whole house. Which is better?
It depends on your budget. Aqara devices are certainly more expensive but is definitely way more stable especially their sensors. The build quality is generally better as well. Problem is that Aqara devices/hub doesn’t work with Tuya devices and you’ll need to carefully plan for one or both ecosystems for it to work.Deciding between aqara or tuya system for whole house. Which is better?
That’s tricky.No, can't work. I found out that Toshiba circuit system line diagram on physical controller is based 36.7KHz. Hence common standard 38KHz receiver will have issue.
Sending all the while no issue just that if wanted to decode the actual IR from 36.7KHz is not possible on 38Khz receiver. So far Toshiba, Panasonic physically remote are based 36.7KHz, not sure other brands.That’s tricky.
Any issues sending command with the broadlink?
cool, so just need the correct ir receiver and tasmota supports itSending all the while no issue just that if wanted to decode the actual IR from 36.7KHz is not possible on 38Khz receiver. So far Toshiba, Panasonic physically remote are based 36.7KHz, not sure other brands.
Anyway, I'm able to resolve the issue now as I do have 36Khz receiver in my drawer. Hence now using physical remote able to update the status too using tasmota-ir.
can I check for those lighting with 3 colors, daylight, warm light, and yellow light is it possible to use a smart switch? Or is there anything i need to take note of when buying ceiling lights for the smart switch?
Also i am buying KDK E48GP. Is it also possible to connect it with smart switch too ?Anyone has experience with it?
TIA!
For my remote fans, i utilized this method for ac, but install on ceiling fan.For those with Home Assistant, which ceiling fan have you integrated with? I am sure you can use a RF blaster to remote control the ceiling fan but you will not be able to get the state information, e.g. someone use the provided remote to switch fan speed, this will not sync to HA. I've seen some mentioned about PO Eco fan using tuya app and tuya integration, does it work in HA?
Then use a script that detects ir code for low/medium/high which updates fan speed.
Obviously something like ifan04 would be better, but this is cheaper
Wow, the Haiku fans are really expensive, starting around $2K. I used Broadlink RM4 mini for my ACs, maybe will consider the RM4 pro.
I am using 2x Haiku ceiling fans (now called bigass fans) which integrates locally using wifi. Expensive fans but integrates directly with HA which also provide state information. Comes with motion detection control that you can use for setting automations with your other smart devices. It should also be using the ESP32 chip from Espressif.
I had another two non-smart Elmark ceiling fans which I use bond hub to control. I also use my bond hub for my somfy motorised curtains.
Thanks for the replies but this appears to be too much work for me. Maybe I will consider the Sonoff iFan04.
can, if the switch supports multi click action (eg single, double click, long press etc).
Set light automation for each action.
I’m using device group so it always works without relying on automation
You mean the app?ok thanks! Is there anyway to control the light as well?
such expensive fan must be life time warranty?Well, due to inflation and Singaporean insatiable demand for smart devices, and sleek looking ceiling fans, it just gotten more expensive.
It wasn’t this bad when I bort mine 6 years ago.
ya through the app. I saw a few ceiling fan smart switch but looks like only able to control the speed but not the lightYou mean the app?
install those small smart relay inside the light enclosure, then can use smart switches to control those relay to control the light.ya through the app. I saw a few ceiling fan smart switch but looks like only able to control the speed but not the light
Haiku has 3 models locally. The cheapest one below 1k can be upgraded to WiFi with a module that costs $100 according to their local distributor.Wow, the Haiku fans are really expensive, starting around $2K. I used Broadlink RM4 mini for my ACs, maybe will consider the RM4 pro.
Tks but I need IR + RFgoogle this ir blaster remote model zs06 by tuya
