v1hypersg
i dont mind zigbee switches because i intend to get a gateway
is there any problems with not using wifi or RF or bluetooth ?
so moes switches zigbee model, no need neutral but their website says otherwise
aqara does not need neutral but their product range is less than moes
ferbulous
here
wifi version, you can customize even further with custom firmware
Depends on your usage, rf control is useful if your hub/wifi goes offline so can still use rf remote to control
v1hypersg
ferbulous, thanks for your time to reply and answer my questions,
referring to your link for the smart switch which need no neutral and capacitor,
so i just get the wired hub under the same page, and it will work ?
this item below
https://shopee.sg/MOES-Smart-Multi-...7c&xptdk=1faa9663-bd99-4daa-9871-e12ce8421b7c
is it the same as the below item ?
https://moeshouse.com/products/moes-gateway-mhub-ms?variant=39876630347857
but i also need a water heater switch which should be this one. right ?
https://moeshouse.com/products/moes...imer-for-heating-water?variant=45469471375675
as i have a ceiling fan in living room, guest room and study and also aircon i all the rooms
i should get this IR+RF blaster but this is wifi and not zigbee so my above hub cannot connect or control it, right ?
https://moeshouse.com/products/wifi-rf-ir-universal-remote-controller?variant=44899193717051
also there is a homekit version which means. buying the hardware then i can use homekit or google home ?
https://moeshouse.com/products/smart-zigbee-homekit-hub?variant=45008906682683
does moes have a wifi. zigbee and bluetooth and homekit all in one so that need not buy so many but in the case if need to buy so many, which are ones which i need to buy ?
ferbulous
this item below
For the hub, you can just get a cheaper tuya homekit zigbee hub from lazada/shopee.They work the same
as for devices, you need to get the ones that are supported based on the zemismart list. If you get something like zigbee siren that’s not listed it won’t show up in homekit
no hub for bluetooth/wifi for homekit. Just zigbee
use homebridge to get ir remote from broadlink or tuya working with homekit
v1hypersg
just a question,
can moes zigbee hub control or connect to aqara switches ?
as per discussion, moes have many bits and pieces but not confident their no neutral reliability,
aqara though less product range seems like their no neutral is more reliable. based on read up and youtube videos
so if one brand hub can control other device then i can get both brand to work within 1 app
but if cannot then i can get moes sensors and aqara switches with their respective hubs and use goggle home to control all,, or this is not workable ?
ferbulous
No, at least until they implement matter on their hub
I've been using tuya no neutral switches for a few years now and no issues so far.
Yes
By the way for homekit ir remote for ac, you can grab this ir remote and install this.
Should work directly with homekit
kun1he2
Anyone have a mix of Moes and Smatrul Tuya Wifi switches?
Suddenly have two Smatrul switches malfunctioning one after another - looking to try out Moes as replacement.
v1hypersg
sorry to butt in again,
just to express what i understand before taking the big leap,
currently, have 4 broadlink smart switch rf+wif and 1 tuya wifi water heater switch,
want to switch to zigbee and get rid of the above as the smart switches cannot connect via app and remote control, also have 4 kasa wifi switches to control some appliances via timer and turn off via app
1. wifi vs zigbee,
if wifi down, then no control but zigbee if wifi down, still have hub to broadcast,
but zigbee hub if only wifi then cannot control the zigbee hub during wifi down, hence there is a bluetooth and zigbee hub,
2. for wifi switches, directly use app to control via home wifi using 2.4ghz, no need hub
3. for rf+ir blaster, use app to control via 2,4ghz as not much zigbee rf+ir blaster
plan :
1. buy moes wifi smart socket and rf+ir blaster to see can control ceiling fan and aircon and if can replace current kasa smart switch and remote on off ceiling fan and aircon
2. buy a moes smart switch and zigbee gateway or hub to control by replacing one of existing broadlink switch as when it turn on locally, it will flicker and i think did not install capacitor
if item 2 okay, meaning local on/off okay and can control via app properly, no flicker or app lost control after 1 month,
then fan out to buy additional 3 more moes smart switch and happy,
if moes smart switch ko during 1 month or still flicker, then jump to aqara 1 smart switch and hub to demo again before buying more,
touch panel vs rocker switch, any distinct advantage ?
my experience with existing broadlink switch, hands wet no worry when turn on or off, but rocker switch worry if wet fingers touch or mechanically might fail after xxxx number of times,
can anyone help to clarify if any above assumption or understanding is wrong ?
thanks in advance
rescapind
Hi,
I'm doing reno for my unit and would like to set up smart home.
I'm using Home Assistant with Zigbee2MQTT.
One piece of hardware that I cannot decide on yet is the wall socket. My desire is to make all the wall sockets smart (able to be connected to Home Assistant) without the additional smart plugs.
I found these 2 potential solutions:
1. https://www.smart-home.com.sg/wifi-products-wall-plug
2. Line8 is releasing the wifi-enabled plug for their powertrack system.
Not sure whether any of the above is working with Home Assistant.
Aqara has some of these wall socket products but they are not for Singapore plug.
If someone has this figured out, appreciate your sharing.
Thanks.
Alphas
Hi,
Thanks.
There are zigbee wall sockets on tuya platform. https://s.lazada.sg/s.bCHTs
ferbulous
Hi,
Thanks.
Ask their support team which chip they’re using. Probably rebadged tuya switches, can still install esphome
ferbulous
1. wifi vs zigbee,
plan :
thanks in advance
There’s uk version of tplink kasa switches? I thought only got us type
i still prefer button switches for the feedback
BeanFarmer
Has anyone managed to control their PO Eco Fan in Home Assistant through the Tuya Integration? I can control the light but not Fan. Fan just shows up but controls are disabled
Devilsire
Hi guys, any reliable gadget for toilet light motion sensor to turn on light, and say turn off light after 5-10mins of no motion detection?
currently toilet light just using smart e27 bulb via wifi / tuya
read up abit and seems like wifi model of PIR sensor is not too reliable (delay), zigbee version less delay but the PIR also may not detect motion accurately etc, especially stationery human etc
what about this product with a manual backup scene switch, anyone have experience with it?
bf526338e1ea3433233f402e7366d129
Read up further seems like there's this newer mmWave sensor for human presence, but alas can only be powered via usb 5v or 220v
ferbulous
That one just the same, just for motion.
Mmwave is the better option but since you don’t want it plugged in
get the zigbee version, longer battery life and set longer delay like > 8minutes so it doesn’t turn off when you’re sitting doing your business
Devilsire
sorry newbie to zigbee here,
anyone can advise if zigbee switches, connected via zigbee/bt hub gateway (and integrated into google home) is able to comms with other wifi devices?
eg. possible to control wifi light with zigbee switch + hub?
ferbulous
not directly but you just need to configure the automation/scenes for that
