pikapig1
Guys, im so new to smart automation and i need advice even after i watched tonnes of Alex teo vid and read thru the pages here cause i have no tech background.
I love zigbee for its price and the range of products in the market
I love aqara for its sensor.
Based on my current needs, what would be a good ecosystem for me?
Needs
-smart non neutral switches
-smart plugs to control corner fan
-motion sensor (wire or non wire) for toilets and house entrance when you step into the house.
-ir/rf controls for ceiling fan, curtain, ziptrack and aircon
-compatible with google assistant or alexa or samsung smartthings
-toilet smart concealed ceiling downlight that allow dimmable function
I understand that aqara sensors are good, but thei price is higher especially their hubs etc.
Zigbees except for moes, im not sure what is reliable as i read that not all zigbee/tuya is reliable?
As much as possible, i want to avoid 2 hubs. Appreciate some advice. Thanks
rescapind
Needs
I got Decken fans (ceiling fan and corner fans). Not yet installed (flat still under reno). They can be integrated via Tuya into my Home Assistant setup.
wacko
Needs
you don't need a smart plug for corner fan, leave the fan plugged in and powered, and control via the fan's remote, either directly using the physical remote, or through a IR or RF blaster (assuming that it is not a "smart" fan).
motion sensors will only practically work for turning on the lights, it is not a solution for turning the lights off as they require constant motion to stay activated.
if you have at least a single Aqara component, I think would be best to try to do a as complete as possible Aqara system.
HMAN
for those that is sticking to Google home.
Google has released the Google home routines with [script editor] which is more flexible to control the device event.
now I can put in close loop event based control.
like if I switch off the last light, it will trigger to shut fans,tv and others.
1a2a3a
Hi, need some advice here.
Currently have echo and rm4 pro controlling my fan, Aircon, tv in my room.
my bto house is getting ready so thinking of doing smart home. A few question that I have.
1) broadlink cannot integrate with Apple home kit so the option would be to use Aqara? (I don’t want to go through the Homebridge thingy)
2) can I co exist aqara and broadlink and use echo to voice command those 2?
3) I can’t decom broadlink because aqara don’t do RF blast. So unless I buy a fan that is IR/smart/wifi, i will still need broadlink for RF?
4) I don’t get the concept of smart switch. If broadlink control light, then what is the switch for? Is it because the smart switch is for those lights that are not attached to a fan?
My current thought process is…
Aqara
Curtain
Fan
Light
Aircon
broadlink
Fan
Light
Aircon
voice assistant
Echo on mbr
Sonos beam in living
Google nest in kitchen
this should covers everything I need? Is there anything I need to pay attention to?
Appreciate any comments.
hwmook
Aqara
Curtain
Fan
Light
Aircon
broadlink
Fan
Light
Aircon
voice assistant
Echo on mbr
You mean your whole house got no wall switch? I got so many light switch to control, what can your broardlink RF switch do to my light switch?
1a2a3a
Of course got wall switch. I’m trying to understand what’s the benefit of having the smart switch when rm4 can switch on and off?
MonoByte
Hi, for those that recently gotten their motorised curtain, is it still safe to get from taobao? any recommendation?
will it be geo-locked like other smart devices i.e. robot vacuum? thanks
hkchew03
Tuya got no region issues.
reiser
I would like to install a smart system in my house but I am not techno savvy, so I would like to engage a smart switch company.
Any recommendation?
IceX
a noob question here.
I've some smart home integration in my current home now with google home, broadlink and mi home.
I'm changing a new router next week(same ISP but different brand of routers, previously using Asus and now switching to TP-Link). Will there be issues in reintegrating all my smart devices?
I'm afraid I need to set-up everything again.,or is it simply just use back the same network id name and passwork when setting up my new router? Anything I need to take note or let the technician who is coming down to set up knows?
Devilsire
no issues, i recently switched router brand (xiaomi -> tplink) too and all IoT devices auto connected as long set same SSID/pw
stresskiddo
Thinking of buying smart curtains from zemismart, any affordable curtain installation guys you all can recommend ?
mc_007
Any review on Outsmart ZigBee smart downlight? Wanted to buy downlights that I can change tone and brightness and do not need neutral wiring. Any recommendation?
IceX
i just changed my router today and now all my smart devices are not connected despite setting to same ssid and password.
any idea how I can change the wifi network for my google home and broadlink? I tried the methods listed in google's support but I cannot find any forget wifi or change wifi options.
Elon Jobs
Hmmm…cannot be. I changed my router twice and no issues so long as SSID and password remain the same for my Google home mini, Broadlink hub and switches, Tuya hubs and Xiaomi CCTV and robot vacuum.
Devilsire
check that u dedicated a ssid with same settings (i.e including security type eg. WPA2/3? , 2.4g for IoT)
some newer routers/brand eg. wifi6 may have a separate IoT channel for u to set 2.4g ssid
