TanKianW
**GOOD WATCH: Home Assistant's Year of the Voice 2023**​
Local voice control with privacy might come earlier than we expected. Finally, a smart local hub that runs on ESP32. Though the voice commands are still limited but we may see much faster development next year. It might be time to get a unit for thinker-ing very soon.
For those who are interested in playing around or test with the ESP32-S3-BOX (Lite/3) voice control development kit using Home Assistant, feel free to purchase from Taobao where quite a few vendors are offering.
The integration and configuration can be found here on official HA website:
https://www.home-assistant.io/voice_control/s3_box_voice_assistant/
Community discussion here:
https://community.home-assistant.io/t/esp32-s3-box3/638287​
Devilsire
hi guys, is it common for tuya zigbee smart scene switches (mine from Moes) to not be able to work well with google home?
the scene switch was setup and works fine in tuya app but i'm not able to set it up correctly in my google home. it shows up in my devices list but only shows battery % and nothing else (cant click or switch on/off anything from google home). when trying to create an automation from google home is also the same - starter option is only when it starts or stops charging. (https://quickshare.samsungcloud.com...55846LosIqzj&currentIndex=1&linkUrlVersion=V1)
The same for tuya rf remote - works fine in tuya app but was only given the option of on/off in google home. any way to get the full remote options (i.e. for fan, to control fan speed as well) working in google home?
there's no sceneswitch that works with google home with full integration. eg. tuya smart scene switch only works directly with tuya devices shown in tuya app.
there's a indirect workaround though, i bgt this tuya zigbee bulb with google home compatibility for my table lamp and set my zigbee switches to different brightness on the bulb (in tuya/smartlife app)
Then in google home, set automation trigger based on the brightness % state of the bulb
Eg. Scene switch 1 -> Brightness 39% -> Triggers automation to turn on Xiaomi Fan + speed 80%, Scene Switch 1 dbl click -> Brightness 45% -> Triggers IR remote to turn on AC / TV etc
Tuya ir / rf remote works fine, just have to configure in Tuya/smartlife first and connect link to google home to show up the linked ir/rf controls
1a2a3a
Can I know the difference between Yeelight smart track curtain vs aqara one? The price is like almost 50% difference
elvintay07
Suspended
If want to control aircon, is aqara hub or sensibo better? Sensibo is like $180 and can control 1 aircon. Aqara hub only $40
icyfira
Just sharing that Aqara China switch can't add to global M2 Hub.
Tried the manual way to add but it's not appearing in both Aqara app and GH
mc_007
Anyone bought smart Tuya ZigBee switch from TB? Any feedback cos the cost is so much affordable than buy in SG. Thanks
hkchew03
Will work, but pretty much most Tuya branded has questionable QC due to open sources and mostly just rebranding, you don't know who manufacturer the product unlike Aqara/Xiaomi which is made by Aqara themself.
hkchew03
Are you sure your AC is able to connect to Aqara in the first place? From what I see, Aqara method is just using IR remote, basically not much different from using the original IR remote, and you need line of sight. Any phone with a IR blaster will work the same, except without autoamtion and so.
elvintay07
Suspended
I thought sensibo is a IR blaster also?
hkchew03
If it is just a IR blaster, than both will only be semi smart at best. You can trigger the remote, but you have no idea if it is triggered or misfired as your AC does not report back its state.
elvintay07
Suspended
So expert can share sensibo got what difference?
hkchew03
If it is just IR blaster like you said, then no diff. Both need LOS and has chance of misfire. Base on installation, only difference is sensibo can be stick on extremely close to the AC, increasing reliability. Aqara hub a 2in1 function and installed in centralised area for better connection with other aqara devices. Sensibo seems to have some air monitoring sensor tho.
One could probably just use a $15-20 zigbee/wifi universal remote to achieve similar effect. End of the day both will just allow you to remotely control the aircon without knowing the aircon existing state unlike manufacturer built-in smart AC (daikin/panasonic)
sellwatch
anybody can reccomend any zigbee hub to link Ikea bulbs to Alexa? The ikea hubs are pretty steep in cost.
port80
Hey folks, has anyone had success with home assistant in Singapore?
What are some shops that are best to buy compatible devices, etc and offer advice? I'm a software engineer looking for a platform that is open and compatible. Planning on about 50 switches + outlets, AC and blinds.
