Devilsire
Thanks.. went to DIYovation and the sales there said that i can use dumb switches with the smart dimmer lights. Will connect to Zigbee hub and use App/ Google to tune the colour and brightness.
yup, i used to rely on google assistant for my lamp dimming as well.
recently bought this ~$10++ wireless zigbee dimmer knob https://shope.ee/5phUXH8z1X which is more handy to adjust physically accordingly instead of keep repeating voice commands to get suitable brightness/color if u get what i meant
kun1he2
Any recommendation for rain sensor? Those water leakage sensor will works the same way?
I bought a water leakage sensor to try out for sensing rain.
Doesn't quite work for light showers as it needs the two metal contacts to be connected with water.
But I guess it still works as a fail safe for heavy downpour or extended raining period to trigger your programmed actions.
Devilsire
hmmm like what kinda useful automations? curtain i doubt its of much use, if only there's automated window closer :ROFLMAO:
mc_007
Like others mentioned, dimmer switch won't work with smart downlight
Easiest way is just keep the dumb lights always on or use smart relay like sonoff mini with matter and enable decouple relay option.
Then, add wireless zigbee switch/dimmer configure automation for dimming/color change to the smart light based on clicks (1x/2x click, long press etc)
I want to use Tuya ZigBee..can advise what smart relay that I can use to decouple relay option?
I just want to on/off the lights with physical switch. For brightness control, I am ok to use App. Really not used to need to take out handphone to on/off lights.
ferbulous
the one mentioned before, sonoff mini with matter (MINIR4M), can be added to tuya app.
with detached mode on, it won't cut the power to the smart lights if someone toggles the switch.
you can use the on/off switch event in the automation to toggle the smart lights.
You're using for multigang or 1 gang switch?
claudiusje
if getting smart door lock, doorbell, smart switches to connect to lights, ir blaster to control aircon/tv. i only need neutral wire for the smart switches right? thanks!
wacko
yes, and only if you are intending to use smart switches that require neutral wiring. there are non-neutral smart switches as well.
v1hypersg
just to share my experience today,
install 5 x zigbee smart power plug - it remotes turn on certain electrical appliances in different parts of the house and accoring to MOES, it help to spread the zigbee signal throughout the house
install 1 x touch zigbee water heater switch but it failed, it could not work so revert back to previous wifi touch wifi water heater switch
have to buy a button zigbee water heater switch and arrange for electrician to come to install,
install 2 x 2gang zigbee star ring switch
install 1 x 1 gang zigbee star ring switch
all working well now
note : star ring design is not so ideal as it is not a full plate based installed on the box and it is a metal piece so it takes some time and skill to adjust the screw to make sure it is secure and tight,
so star ring design is not so good, should have bought the previous generation instead, hope the better electronics can last longer
also bought a zigbee luminance, temp and humiditiy sensor for toilet to monitor and control light and ventilation fan,
also bought wifi ir rf blaster x 2 for study to control ceiling fan and aircon, yet to set up
another unit will be for bedroom for dyson fan and aircon but yet to setup
but now remote control, timer control for the light switches are fine,
so before come home can set water heater to turn on
after shower can timer to turn on ventilation fan and turn off after few hours
just my experience to share
der_kannichen
Hi all
Is there any one using WYFY smart home system?
I have bought WYFY smart switches, IR blaster, and hub recently.
Currently exploring the option of buying Dooya curtain motors from Taobao.
Questions:
- Is the Dooya curtain motors compatible with the WYFY hub, and added to the WYFY app?
- Do I have to buy specially made curtain track to go with the curtain motor?
ocean9998822
Hi Gurus!
Starting my smart home journey.
Any recommendations for:
1) Smart Switch
2) IR Blaster
3) Door Sensor
that are compatible with Google Home?
Devilsire
Hi Gurus!
1) Smart Switch
2) IR Blaster
3) Door Sensor
imo just go with Tuya/SmartLife (cheapest OEM gadgets) if using Google Home
invest into zigbee if prefer lower latency (like few secs), or just wifi will do for most
Devilsire
I'm slow, just came to know that Google home actually supports script editor now
I have 0 knowledge / expertise on programming / language but am still able to play around to with it abit to get some automations working
boombastick91
Recently swapped out my smart switches at my living room and master bedroom, everytime I turn on a switch at my living room, the ceiling fan in my master room will be activated for a short while with a "beep" tone and the light in master room will flicker for one time.
Don't remember this happening with my previous switches, anyone has any suggestion how to resolve or is this due to some wiring mistake I made or a faulty switch?
mc_007
Any review on HomeAuto smart switches vs. MOES smart switches? Saw the MOES switches are cheaper than HomeAuto ones. I assume MOES switch can work with any brand of dumb lights?
Looking to run Tuya Zigbee. Can recommend a ZigBee Hub?
Thanks
hkchew03
Thanks
Quick google show HomeAuto use their own app?
jikilan
In sg context. I got a feeling better to go all in aqara devices after using unbranded /zenismart ZigBee hubs for a few years if don't wan tinkering with HA. at least I have door bell, camera, curtain in the same app. Especially now it is one of the brands that updated to support matter. I oso dun need to worry which voice assistant ecosystem to go with. More well balanced. I think ceiling fan could be forgotten by the manufacturers, since ZigBee version seem non existent. Local brand like prism does not seem interested on matter according to the insider that I have access. As for tv, washing machine and fridge all really need to wait until 2024/2025 for matter to come.
Is my understanding correct?
