kun1he2
I'm just using Tuya based OEM smart plugs. Works well and can monitor power usage
Same here - works well but do keep some spares handy - they aren't as robust.
Perhaps it's because I have a tendency to look for the most bang-for-buck listings :cautious:
flikmy
Hi,
a quick straw poll of what brand/model of smart socket/plugs are you using ?
don't seem to have a dominant brand
Just replied this in another thread (thread link)
Anyway, some 2 cents on my side, unsure if others will have the same.
Have bought about 5 tuya oem branded round smart plus (the Smartful ones). About 3-4 have died within 1-2 years. Some even faster. So had to replace them which meant that I would need to re-do the automations for each of the plugs which can be a pain.
However, recently I have had a single plug (same round one) that has been showing higher power usage than normal. In the first year of using it, it only used under 2kWh per month. It powers a low power led bulb. The past 3 months, power usage for this plug has increased to 20kWh per month. So rather suspect. I've not changed the bulb nor the schedule for it. The bulb is around 5w and runs about 12 hours or less each day. So under 2kWh per month makes sense.
My worry is whether the plug is doing something "else" than what it's supposed to especially as it is connected to my wifi. I guess being wary about what someone else posted earlier (link on smart plug hacks) as well as lower longevity of generic plugs, it might be better to get more reputable plugs?
I've now moved to Prolink (mainly because they also use Tuya/SmartLife platform) but they are more expensive. The plug is slightly narrower so would be easier to fit other switches next to it. The external build also seems slightly more sturdy but time will tell. It only has 1 year warranty compared to TP-link Tapo's 3 year.
Separately, I also bought an Aqara US plug (only 1). Had to use a UK to US converter with it but it does work well. Unfortunately, it's really hard to get and expensive (I think I paid about $40). The benefits are that it's on Zigbee and is fairly reliable so far.
hkchew03
Could be due to firmware update causing messing data translation issues on the plug. I have heard from people using Moes and some other brand, only recently replaced one switch out of about 8-10 switches in the past 2-3 years from using. Expect durability to slowly increase as the tech mature.
flikmy
I initially thought about whether there was some data translation issue, but I've never updated the firmware on it but the problem just appeared recently and continued. So decided to stop using it.
Yeah, things are still fairly new. Even with Prolink alone, I think their plugs have updated 2-3 times from 2020? So it's going to be hard to tell which version is more reliable.
keith
Hi,
thanks to all replies, i have been using local brand Aztech/Kyla socket/plug for 2~3 years, sample size is 3x, and for low Amperage purposes (to power cycle devices). though they are pretty stable. but it only allows its own app.. :(
Billyboo
Anybody with the aqara z1 pro 4 gang smart switch? Is the 4th rocker able to connect directly to control light or purely wireless only? Need a 4 gang smart switch and wanted all to be aqara :(
ferbulous
4th one just a scene switch
Try grab a 4 gang switch with matter support and add to aqara
hkchew03
4 gang almost impossible to find, so far only saw 4 gang switch module.
Programme it to control light?
Billyboo
hkchew03
Taobao got
【淘宝】https://m.tb.cn/h.5BdNpWnDlD1qBsj?tk=Ts56WpBhian CZ3460 「Matter协议可跨平台智能开关HomeKit定时Home Assistant墙壁开关」
点击链接直接打开 或者 淘宝搜索直接打开
Saw this previously, unfortunately on zigbee, also design doesn't match all other switches.
can programme it only if I get smart bulbs instead right? 🤔
Will check it out, thank you!!
All wireless switches are mean to assign to control devices as long as they are under the same ecosystem/app.
Nashstruck
The problem is the smart dimmer is not compatible with SOL lights. Not sure why
Hey bro - did you manage to figure out a suitable smart dimmer with Sol Luminaire lights? I also purchased the lights that have dimming function but now trying to find a suitable smart dimmer that is compatible with it.
Nashstruck
Hi, am in the midst of my renovation and my wiring is already done. Am looking for a dimmer switch to use with my Sol Luminaire lights (all dimmable). Have bought a bunch of Aqara D1 switches and have shortlisted the Koble Smart dimmer switch (slide up and down to dim) as the dimmer. So here’s my question:
- is there a way to wire both the Aqara and Koble switch together, such that I only need to set the Dim setting once on the Koble, and then whenever I switch on and off the Aqara D1, it wil “remember” the dimness setting? I don’t intend to use the on/off function on the Koble since the Aqara can do that. I’m concerned because both are smart switches, and am not sure if the Koble can be configured such that i only use the dimming function and ignore its on/off function.
- Also, is there a way to configure such that if Aqara is set as the main switch to my lights in the room, then I can still control the on/off function via the Aqara app?
Hey bro - did the Aqara or Koble switches work with your SOL Lumainaire lights?
vade
Hi all,
I'm going to start reno of my new place soon, and I'm new to smart homes / home automation so need some advice please.
My place is a cluster house with a basement and 3 storeys (each level is around 700sqft). I'm thinking of using Aqara smart switches. Do I need one hub on every level? Or just one central hub on Level 1 or Level 2 is good enough?
flikmy
Hi all,
I think it would depend on how many zigbee repeaters you will have. Power switches with neutral can function as repeaters but non-neutral ones don't. As an example, I live in an apartment and my M2 hub in the living room (west side of the apartment) would barely connect with sensors in my bedroom (east side of apartment). There were about 2 concrete walls in between. I didn't have any repeaters and so decided to add-on the aqara E1 hub in my bedroom to support all the sensors, switches and buttons in the east side of my place. I would recommend to get just one hub first and test it out. Aqara app would show the signal strength to each device. Adding extra hubs isn't too hard, but you would need to redo the automations after moving your devices to a different hub.
Separately, there's a 128 devices limit for connection to one hub. So you might need to have more than 1 hub in a large house.
vade
Thanks for the explanation. So in theory, if I'm using Aqara switches with neutral, they will act as repeaters ro provide coverage across my whole house and (in theory at least) one hub should be sufficient? Do the repeaters only work on the same floor or across floors as well? Other than coverage consideration, if I'm using only one hub, will there be a delay for devices which are "far" away from the hub?
hkchew03
Delay should be minimal within 1s as long as signal coverage is good. Repeater will work as long as signal is reasonably good and stable. You can always choose to install the hub in a relatively central area. Also most house are wired without neutral at the switch, unless you are rewiring or wiring a new place, this isn't feasible.
vade
Thanks, and noted on the need for neutral. I'll discuss with my electrician on this.
Some further questions:
1. For those who use Aqara H1 switches, any suggestions for non-smart switches which can match the look for consistency?
2. If I'm already using smart switches for my lights, is there a need for smart lights too? What's the use case for a smart switch + smart light?
