Billyboo
Not familiar with Aqara, but generally most company that claimed "smart" implementation of AC or fans with remote is only semi-smart. It basically just a additional universal remote to issue control. It allow you to control the device outside of the room/home/wifi network, but does not reflect the actual state of the device (AC temp/fan speed etc). ie to say, if there is a missed remote command (object blocking IR signal for remote), the smart system will not tell you the device isn't switched on. Generally it work fine, but is not 100% reliable.
The real smart AC are those implemented by manufacturer (with Wifi control etc) with AC connecting to your wifi network and tells you the actual state of the AC and not the stats of the issued IR command.
Things are much less complex with simple devices like light and fan that does not utilize remote or have physical toggle for speed/etc, all these can be controlled by switch on/off state.
Thanks for the info! Can I ask what switches/ hub you are using currently?
xxnewbiexx
Bought one of these online and have electrician to install it for me. After he install it, (not setup yet) the switch cannot turn on the lights, is there any tip to resolve this?
From the manual, it seem to be even without app configuration, the switch should still be able to work in manual mode. What could be wrong?
ezihome
Wiring correct?
How many pieces you bought? All pieces not working?
The physical button press should work for normal on/off, without any setup.
xxnewbiexx
Wiring correct?
Thanks for confirmation, new at this and electrician is also new to this device. Bought will go onsite tomorrow and check and perhaps try the other unit
Arandalo
This type of smart switch I think need to install the capacitor at the lighting connection, if your wiring don’t have neutral wire.
hkchew03
Im guessing
- You bought the wrong type/seller send wrong type (neutral/no neutral)
- Electrican installed wrongly (very unlikely since its just 2 wires for 1 gang.
- Product DOA.
Switch should still work without linking to wifi/hub.
xxnewbiexx
I'm using Shelly WiFi relays for wall switches. Installed ceiling mounted WiFi access point in the middle of the house to ensure good coverage throughout the house. No issue with coverage so far, quite rock solid.
Doesnt matter WiFi or Zigbee, it's paramount importance to ensure good coverage of the respective wireless protocol. I do have 30+ zigbee devices as well, mixture of relays, bulbs, plugs, LED controllers. Initially had coverage issue for one LED controller in the master toilet as its the furthest one from coordinator, through thick toilet walls and I don't have a zigbee router in the master room. Bought a couple more zigbee plugs, spread it evenly across the house and one in the master room to strengthen the mesh network. Thereafter, no more connectivity issue.
Does your zigbee relay also function as router? If it does, then lesser chance of coverage issue as it will be spread across the house. One thing I tried is that pairing zigbee( that can function as router) devices nearest to coordinator first, then outwards towards the furthest location does help in ensuring good coverage (though the network will eventually self heal for the best route). Zigbee sensors and wireless devices will be the last to be paired.
Hi when my electrician install my relay, I can't control igd via manual switch. Internet not working at my place yet so no configuration is done.
What could be our error? The installation manual show is quite simple and I am using a relay with neutral connection
ezihome
What relay are you using? Do you have the wiring diagram of the relay to be connected to the switch? Confirm its wired correctly?
Can the relay on/off be triggered by physical switch connected to it? Different relay have different configuration and features. Not all relay can be connected to a physical switch
For mine, Shelly WiFi relay, by default the physical switch will trigger toggle and follow on/off according to the switch. So gotta check for the particular relay you using.
xxnewbiexx
I suspect the error I am getting is because the electrician has set up 2 switches to control a set of lights. Do u have such a scenario in your setup, if u do, how do you resolve it?
ezihome
You mean it's set up as 2 way switch?
I don't set up my relays as 2-way as it's not capable to do so. Gotten my electrician to close down any 2-way wiring of original switches. You can try to set up as normal 1-way first to eliminate that doubt.
username03
Few questions for smart switches for lights etc.
1. For heater, have to be above 20A and must have neutral wire capability? This is what my electrician advised.
2. For normal lighting or fans, is it no need for neutral? The switch I'm looking at can work with or without neutral.
Arandalo
For 2. it actually depends on your existing wiring. Even if you use a smart switch that can work both with or without neutral wire, if your wiring no neutral you will need to install the additional capacitor at the wiring near near the light or fan, which is not easy to do given that it’s located high up at the ceiling and also the existing wiring may not be easy to modify to add in the additional capacitor.
I personally tried to change my switch to a smart switch but because the existing wiring has no neutral wire, there will be constant flickering and the only way to resolve is to install the capacitor at the wiring near the light. But the light is those LED tube light which connects by rotating the pins at the end into the LED tube light holder/fixture, making it quite tedious to install an additional capacitor for a layman.
username03
My lights or fans not up yet as still in the midst of reno. All cables exposed. So adding capacitor shouldn't be an issue?
Capacitor usually only required for lights or whichever items requiring less than 10w right?
All will be installed by electrician of course as I'm not savvy and wouldn't want to gamble my life with electrical stuffs.
ezihome
1.yes have to be above 20A. Heater switches usually double pole, so would already have neutral.
2.non-neutral smart switch can work. But like what others mentioned, have a chance of light flickering depending on your circuitry. I had mine non neutral switch in bomb shelter, do observe light flickering sometimes when it's switched off.
hkchew03
Make sure to show electrician of the circuit diagram for capacitor installation. Many electricians have limited experience on smart devices. Or just get switches that does not require capacitor.
Arandalo
Make sure to show electrician of the circuit diagram for capacitor installation. Many electricians have limited on smart devices. Or just get switches that does not require capacitor.
There are switches with no neutral (wire) and no capacitor required but they require a hub (usually Zigbee) to function. Currently in the market like don’t have smart switch with no neutral, no capacitor and no hub (connect directly to router).
hkchew03
Neutral or no neutral with or without capacitor isn't dependant on zigbee/wifi/bluetooth/thread. If you don't want hub, only wifi is applicable. And without knowing what system, it is impossible to advice...
And yes, there no no-neutral, no-capacitor WIFI switches in the market, you just have to look harder.
Arandalo
Looking for Tuya/Smart Life touch screen smart switch with no neutral, no capacitor, no hub. I have been checking the market every now and then and such a product does not exist yet.
