Hi, now I'm using all CN aqara D1 switches, my old aqara hub cannot even connect to CN region aqara app, u mean even if I were to buy a CN M2 hub, I cannot even use aqara app? Must be mi home??I using aqara china for 5 years. Last time works with Google home. Since aqara updated their app, cannot setup china hub le. I believe u just need to get global hub. Switches don't matter.
u can try using cn region aqara app. i faced prob because i installed aqara app from google play store.Hi, now I'm using all CN aqara D1 switches, my old aqara hub cannot even connect to CN region aqara app, u mean even if I were to buy a CN M2 hub, I cannot even use aqara app? Must be mi home??
Oh man, I love aqara app, not that I hate mi home but I prefer aqara since I'll be getting the touchscreen power socket S1E, more themes and screen saver
Ok I have found the root cause of the problem after meddling and researching online.Hi, now I'm using all CN aqara D1 switches, my old aqara hub cannot even connect to CN region aqara app, u mean even if I were to buy a CN M2 hub, I cannot even use aqara app? Must be mi home??
Do note that the 4 gang Aqara Z1 Pro, is actally a 3 gang switch... the buttom button is a scene switch.I would thought that the smart light will be default on and use the smart switch as the main trigger for on / off. My objective for smart light is to control colors and brightness level. They do not have to be mutually exclusive. As my intention for each standard room is a 4 gang Aqara Z1 Pro, I can link it up to a dumb light / ceiling fan and light combo to control remotely.
I will not want to install a 2 gang smart switch for dumb devices and another 2 gang dumb switch for smart devices. Ideally I want to use a smart switch for both smart and dumb devices.
If you want to have mixture of smart and non smart switches with same consistency in the aesthetics, I'd suggest going with smart relays.Thanks, and noted on the need for neutral. I'll discuss with my electrician on this.
Some further questions:
1. For those who use Aqara H1 switches, any suggestions for non-smart switches which can match the look for consistency?
2. If I'm already using smart switches for my lights, is there a need for smart lights too? What's the use case for a smart switch + smart light?
Every switch 1 relay?If you want to have mixture of smart and non smart switches with same consistency in the aesthetics, I'd suggest going with smart relays.
Installing a smart relay behind a normal non-smart will make it smart. Can use the same normal switch throughout the house.
Yes. Get the appropriate number of gang/channel relay for each switch locationEvery switch 1 relay?
Then the relax becomes your smart switch?Yes. Get the appropriate number of gang/channel relay for each switch location
Hi. U have almost 90% of what I have throughout these 5 yrs to smart my home.Hi Everyone, I’ve been reading this thread for the past few hours and am a bit lost. I’m currently renovating my place, and have installed CN Aqara D1 non-neutral switches for my place. I intend to use google home for my smart home setup. For which I have gotten the Google Pixel Tablet and two speaker docks. Now the question:
1. I haven’t gotten any hubs but had intend to get the Aqara M2 hub. However, reading from page 180+ of this thread, it seems like I will not be able to integrate this to google home easily? Is this still true or was there any magical update that happened since 2021? Will the global version work?
2. If I understand it correctly, the Aqara D1 switches work with any zigbee hubs and doesn’t have to be an Aqara one and it should work regardless of where I got them from (i.e CN vs international)?
3. Given the things I have already bought (ie google and aqara switches) and if the above is true, which hub do you recommend that I use for a seamless connection to google home for all my home automations?
If it matters, I intend to have quite a bit of automation scenes and if the recommended hubs will need to consider the following devices:
1. Google Pixel Tablet + Speaker Docks
2. Google Door Bell
3. Aqara D1 Switches (non-neutral)
4. Aqara A100 Door Lock
5. Aqara T1 LED Strips
6. Dreame L20
7. Steigen Drying Rack
8. Samsung Smart AI Washing Machine
9. Xiaomi CCTV
10. Xiaomi Pet Water Fountain
11. Tuya Pet Food Dispenser
Thank you very much!
I'm no guru but I can give u some adv on the abv.
Google pixel tablet will not show when your Google doorbell is pressed. It's not like Google hub or Max hub where it will show and u'll hear ding dong. Pixel Tablet is just an enormous G.Home app. Although they say update of doorbell video pop-up will arrive but it will never happen in our lifetime imo, so I sold mine away. The speaker is lousier then max hub/nest audio also anyway.
Google battery doorbell integrates perfectly in g home and u get almost instantaneous vid through your phone when someone presses doorbell, parcel is detected/out of range, or people walking past your doorbell. The batt life is great too. If u have Google nest hub/audio/mini, they function as doorbell chime. (Note aqara hub of any model will not work as a chime for g doorbell).
Are your D1s CN or global? I have a CN region aqara (1st gen) hub that connects all my CN D1s and door lock, so I can set automations like motion sensing kitchen turn on lights and open main door turn on hall's light. If no hub, ur D1s are jus normal wall switches. And I don't think Global Hub can recognize CN D1s (correct me if Im wrong). Cos back then during covid, there are no Global aqaras everything
Google Home app WILL NOT recognize Aqara CN region hence not able to integrate aqara into g home eco-network (last time can, now cannot). If yours is Global then can add into g home.
Make sure to name all your switches in diff name so that when u hey Google, it knows which switch u wanna turn on/off
Xiaomi stuff like TV and pet dispenser can only be used in mihome app.
You can in turn add all stuff aqara into mihome app to save yourself running aqara app.
So for your case u'll have to have g home, aqara app, mihome & Samsung Smart Things.
I was about to ask the same thing here since currently doing renovation.On a side note, has anyone installed magnetic light tracks in their home?
What brands did you go for and if they are integrated to your Smart Home automations via Home Assistant or Google / Apple / others?
I cannot find much information for Aqara H1 Pro Magnetic track + peripherals and they are also very costly, even just for the tracks itself without driver and lights.
How much did you spend for your magnetic lighting system set up? Looking at doing for my living room and potentially need 20m of track length (5m x 4m) - box shape perimeter, with a ceiling fan in the middle (maybe without light to avoid the strobing effect).
Thanks for sharing your experiences! Must be very frustrating. I’m getting the home smart.sg folks to help with the smart home setup. They got back to me this morning and mentioned that the global Aqara hub can be used with the CN D1 switches. Will need to select “China” region in the app to link/add the switches then back to “others” region to integrate with google for the automations. There are quite a bit of mixed messages around this so I guess will have to see it for myself to really know.Hi. U have almost 90% of what I have throughout these 5 yrs to smart my home.
Yes that's right. I am using Shelly relays throughout my house. Installed behind a normal switch ;the normal switch becomes a smart switch. There are Tuya based (other brands as well, like Sonoff) smart relays as well that works in similar fashion.Then the relax becomes your smart switch?
Get from taobao? Can support Apple HomeKit?Yes that's right. I am using Shelly relays throughout my house. Installed behind a normal switch ;the normal switch becomes a smart switch. There are Tuya based (other brands as well, like Sonoff) smart relays as well that works in similar fashion.
Natively no, you need to install homekit firmwareGet from taobao? Can support Apple HomeKit?
