ferbulous
Thanks for sharing your experiences! Must be very frustrating. I’m getting the home smart.sg folks to help with the smart home setup. They got back to me this morning and mentioned that the global Aqara hub can be used with the CN D1 switches. Will need to select “China” region in the app to link/add the switches then back to “others” region to integrate with google for the automations. There are quite a bit of mixed messages around this so I guess will have to see it for myself to really know.
I’m hoping with the new script editor function, I’ll be able to create a dashboard that shows the google doorbell vid. I don’t really need the sound cause I have a dog so he is my door bell alr 😅 but I’m planning to create a scene to have the LED stripe under my tv console to light up in red (until I turn it off manually) when someone rang the door bell when I was in a meeting or something so I’ll rmr there was someone or a delivery during the day.
I’m actually an apple user (iPhone, iPad, Watch, AirPods) so if google fails then it’s not too difficult for me to change out my operating system.
I have a new question. I’m planning to have two global Aqara M2 hubs for my 1119sqft apartment. I’m thinking to get zigbee repeaters to extend my coverage, anybody knows if I can use a Tuya zigbee repeater? Or I can only use Aqara ones with the M2 hub?
Thank you very much!
If you use homeassistant, you don’t need to worry about the region restrictions by xiaomi.
the led strip red effect can easily be done and a whole lot more
no, you can’t mix with tuya ones.
ezihome
Get from taobao? Can support Apple HomeKit?
Shelly is a European brand. Can get it directly from their website or AliExpress.
For Tuya ones, easily available at most online platforms, Taobao included.
Likewise for Sonoff.
As for HomeKit support, this I not sure as am not familiar with it.
I am using Home Assistant to integrate all my smart devices. Plenty of native official integration for major smart home products/brands. For zigbee connected devices, will be able to integrate directly(regardless the brand) into Home Assistant without an intermediate brand-specific hub.
elvintay07
Suspended
How come? Xiaomi not limited by region?
u_ntitled
hi anyone here using zwave usb dongle with home assistant? I'm looking at Zooz 800 usb is there anyone have experience? Or is there other zwave usb dongle that you suggest with home assistant? thank you in advance
glorygoh
Negative, Global M2 Hub (any hub for that matter), will not recognize CN D1 switches, they blocked le. So cannot China region add, then switch to Others for G.Home integration, no.
ZacharyA
Can get a CN Hub to link CN devices and then link to Home Kit. I believe Home Kit can work concurrently with both Global and CN Hubs.
ferbulous
i used nortek dongle back when I had z-wave locks installed
hkchew03
I went to the CEE Aqara booth last weekend and I can confirm that Aqara devices purchased in SG (or International) can only talk to Aqara Hub sold here (or International). Aqara devices from CN must be paired to an Aqara Hub from CN.
That said, both SG and CN hubs can be paired to Apple Home Kit so it still works, just need to separate hubs.
Although going forward, things will converge towards Matter protocol with just 1 Hub across all brands of devices as long as they are on Matter / Thread.
I highly doubt Matter/Thread will work as you say, all these region lock is implemented by the manufacturer app. Manufacturers are putting in this region lock due to price different between China and Global devices. They use exactly the same protocol and hardware. If its true, then you probably be seeing increase of price of the China devices that support Thread/Matter then, making it pointless to get CN based devices.
ZacharyA
My main priority now actually is to focus on Aqara devices and linking to Home Kit, for others who intend to use Thread over Matter are not restricted to using a Matter hub like M3 but any hub can do which only time can tell which we should be able to see more of in 2H of 2024.
jikilan
Question, if use remote controller, I assumed each temperature up/down is an unique command sent to fcu. But still feel weird that need to press one by one from remote controller. The same also applied to aqara home app. This tells me it is not .So temperature out of sync can actually happen between remote and the app? So do we need to calibrate to start from a same degree in the beginning?
ezihome
How are you controlling aircon from the app? For my Daikin WiFi enabled fcu integrated to Home Assistant , the physical remote control behaves as a dumb control. Whenever the remote is pressed, commands are sent to fcu based on what is set on the remote control. Those settings are pushed to Home Assistant and gets updated.
However the same can't be said for the remote control. If any changes made from Home Assistant, those settings are not carried over to the remote control.
ferbulous
Hi, how do you integrate Daikin to HA?
Are you using Faikin? I still need to get some crimping tool before connecting Fakin flashed esp32 to daikin ac
ezihome
I am already using a newer model of Daikin with WiFi enabled controller (can't recall the exact model of the controller). Connect it to my network by the official app. Thereafter, Home Assistant has an official Daikin integration, able to detect the fcu.
ferbulous
Thanks, i read that local api is removed for newer daikin ac so it’s cloud based at least.
Mine’s 2016 model with optional controller port which I never really bothered until I read about faikin. Till now just using the ir method, curious to try faikin once I got all the wires setup.
Also, does the integration display next service time or power consumption? Seems to be some of the features on the daikin app
ezihome
Next service time, no. I reckon you can set some automation based on duration used or whatever metrics you deem fit.
Power consumption, yes. And a bunch of other data. Illustrated below.
https://ibb.co/tskmn3d
https://ibb.co/c8KYWF5
crazymond118
Can ask where do you shop for smart lighting (track light / magnetic light / LED light strip)?
Seems not many choices in Singapore. Is there any shop in JB selling those or just TB and ship over?
wutawa
Hi
Is anyone using Xiaoai Tongxue? How's the experience?
i am using xiaoai. does anyone know how to customise xiaoai commands? i want it to set alarm and say something with just 1 command. i am using it on my xiaomi pad 6.
ferbulous
Thanks, on the daikin app you’d need ‘premium’ subscription for the extra features like power monitoring etc.
Does the daikin integration just bypass that to get those details?
Also which daikin model do you have
