ezihome
How does relay work? So you just install it inside the wall switch housing in between the switch and the light? And the switch will need to always be in on position?
I'm using Shelly relays. Dumb switch - >relay - > light.
The relay is the one controlling power to the light. The dumb switch button press can be configured to control the relay toggle on/off, or configured to control other smart device through smart home integration.
Other relays work similarly, though not all can connect to a dumb switch. For those that can't connect to dumb switch, can mount a wireless scene switch over the switch box (with the relay already installed in it) to control the relay wireless through smart home integration.
xxnewbiexx
@Xherion
The biggest challenge I have is with 2 way switches. The relay need to be setup in a certain way.
If u r renovating your place, tell the electrician earlier, for my case the electrician created some space below the switch to store the relay. My switches are buried not expose, not familiar with solution for exposed switch. If switch is on carpentry then easier.
Xherion
Thanks to both for the explanation, it's interesting. So the switches need to be kept on at all times right? In order to keep the relay on so you can control the relay from the app?
I am actually currently using wireless kinetic switches now, with wireless modules connected to each light circuits
Xherion
In my case, these RF/WiFi receivers are hidden in the ceiling and connected directly to the light fixtures.
i.e. no need to pull neutral wires to the wall switches - which are just the good old physical switches always set in ON position.
are you using Ganen kinetic switches?
xxnewbiexx
no the relay just act like another switch. Your dumb switch do not need to be on at all time.
Maybe this will be more clear, if relay is not configure or spoilt, the switch still works as per normal like a dumb switch.
For my case, my wife has a particular need for look and feel of switches in the house, she does not like the smart switches, so I use relays so that she can use the switches she like (dumb / ordinary ones) and I could have the ability to have smart capabilities in my light controls.
Xherion
Ah got it. But let's say your wife turned off the dumb switch, and you turned the light on using the relay, then the light will be on, but the dumb switch rocker will still be in "off" position?
xxnewbiexx
In this scenario, it is no different from a 2 way switch.
An example of a 2 way switch is a hall way light. U may have a switch in the entrance of hall way and another switch at the exit. U turn on like in the entrance and turn off light at the exit. When u do this entrance switch remains in the "on" position while when u switch off light at the exit, the exit switch is also in the "on" position.
Hope this is clear
ezihome
The dumb switch does not need to be kept on all the time. In fact, the dumb switch and relays work independently of each other, but with the status of the relay (on or off) will update and sync in the app regardless you control it from app or from physical dumb switch.
In essence wiring wise , the dumb switch and the relay are kind of like connected in parallel to one another. The power to the relay does not directly come from the dumb switch, but directly from mains. Flipping the dumb switch just toggles the state of the relay(ie on or off) , but not cutting off the power to the relay.
And like what @xxnewbiexx mentioned, you can understand the relay and dumb switch behaving like a 2-way switch.
An extension to this, for Shelly relays, it's possible to decouple the function of the dumb physical switch action.
Particularly for my case, I set one of my relays to be permanently on from the app. And I set the action of flipping the dumb switch to be controlling a ceiling light/fan.
This is so I can set an automation such as if I flip on the switch before 6pm, to only on the fan. If I switch on the switch after 6pm to switch on both light and fan. Switching the switch off will off both light and fan.
All these flipping actions of the physical switch will not affect power to the relay nor the state (on or off) of the relay as I havd them configured to be decoupled. In app, I just need to display the controls of the fan/light device.
I find such decoupling feature useful as I have more customizability, especially if using smart relay(or switch) and smart light at the same time.
But of coz, it also works in a similar way if using a wireless scene switch mounted over the relay on the switch box.
ferbulous
If need to avoid some confusion especially on multigang, better add some labels to it.
Or just convert it to momentary type by adding tiny spring
Xherion
Thanks all, very clear now on how relay works.
For my system with wireless kinetic switches, none of the switches are connected to wall wiring, the lights are all connected to the wireless modules which then are connected to main line in DB box / false ceiling etc.
Seems like this relay module like a T1/T2 could replace the wireless modules, and then the kinetic switches can be replaced by H1 wireless switches. Just an option to throw around. The only downside is that the H1wireless switches will needs a battery change every few years.
testerjp
How to set up a home smoke or flood alert system
connection must be reliable
rerear
Is the Aqara Z1 Pro and M3 hub good? Seems a lot of problems purchasing these from CN, was just about to purchase till reading the connection problems with CN services, are they still worth the trouble or should just get SG versions from Lazada/Shopee?
keith
theres work arounds(Google pls) for CN units (via CN hubs), but is not 100% stable... thats for the price of ~50% disc.
For the SG sets, been on testing for about 6 months, all settings stable. actual whole house rollout in Oct.
I am using SG hubs, active sensors, switches , while some CN/JP (sourced) passive sensors.
rerear
How to tell whether my current switches have a neutral, or when in doubt just buy those without need for neutral? Aqara has H1, D1, and Z1; what are the differences?
ZacharyA
Chances are they will not have a neutral wire. But a check only takes less than 5mins.
