ZacharyA
Anyone has used Aqara China and SG products together? Can it work?
It should work, but you need 2 hubs, 1 for each region, and each time you are in Aqara app you must keep changing region to be able to see the region specific devices. But once linked to Home Kit then can control from Apple directly.
Colaice
Hi all, newbie here. Want to ask if I use Aqara Hub M3, Can I connect tuya smart light in Aqara app? Or can I connect with Apple Home?
glorygoh
No luck. Aqara CN hub won't recognize Global devices, I have invested heavily with CN hub and D1 switches already, so now I got no choice but to carry on using all things Aqara, CN ver.
elvintay07
Suspended
Thanks for sharing. Someone said you need a China hub for China devices and a global hub for global devices. I wonder whether should go Zigbee instead? I worry suay suay Aqara go mad, we lose all our Apple/ Google support. Lol
crazymond118
Does anyone know if I can use M3 hub (connect to international server) link to M2 Hub (China server)?
Hockster123
Hi everyone,
I’m in the process of setting up home automation for my new home, and I’d love to get some advice and feedback from this community. My setup will be based on Apple HomeKit, and I’m trying to avoid using Home Assistant to keep things as simple as possible. This means I’m looking for hardware that’s fully compatible with Apple HomeKit right out of the box.
Here’s what I have in mind so far:
Lights:
  • Yeelight Pro magnetic track lights
    Q1: Is Yeelight Pro compatible with Apple HomeKit out of the box?
    Q2: Do I need to use Yeelight’s hub, or can I use Aqara’s hub instead? I’m planning to use other Aqara devices, so I’d prefer to consolidate everything under one hub if possible.
Smart Switches:
  • Aqara switches (I’m considering Aqara because they offer 20A switches for water heaters, and I’d like to maintain a consistent look throughout the house).
Smart Locks:
  • Both the gate and main door will use Aqara smart locks.
Smart Doorbell:
  • Aqara smart doorbell.
Home Security:
  • Aqara camera and presence sensors.
Aircon:
  • This is where I’m a bit stuck. I don’t know of any smart aircons that are HomeKit compatible. One solution I’ve found is using a HomeKit-compatible IR blaster from Japan (Nature Remo Nano Smart IR Blaster with Matter).
    Q1: Does anyone have better ideas or experience with integrating air conditioning into a HomeKit setup?
Ceiling Fan:
  • This is another tricky area. The ceiling fans I’ve found typically use RF remotes, and I haven’t been able to find a HomeKit-compatible RF controller. I’m open to IR-controlled fans, but it’s hard to tell from online pictures what kind of controllers they use.
    Q1: Any recommendations for ceiling fans that work well with HomeKit? Looks are also important to me here. 😅
I’d really appreciate any advice or feedback on my proposed setup. Sorry for the long post!
Thanks in advance!
phayze
jikilan
Short answer. Cannot. Either u use homekit base tuya products or just all in aqara since u already want m3.
jikilan
Hi everyone,
Lights:
Smart Switches:
Smart Locks:
Smart Doorbell:
Home Security:
Aircon:
Ceiling Fan:
Thanks in advance!
For air con, can try aqara m2/m3 with matter.
Fan can try if the KDK works with m2/m3 library if is new fan. Otherwise if you are adventurous, can install aqara T1 inside your fan, socan control from homekit for on/off. Speed wise use remote .
hkchew03
Hi everyone,
Lights:
Smart Switches:
Smart Locks:
Smart Doorbell:
Home Security:
Aircon:
Ceiling Fan:
Thanks in advance!
Doesn't broadlink RF controller have plugin for homekit?
ZacharyA
hi,
Anyone using Aqara H1 switches for ceiling fans or laundry system ?
I will be using H1 wireless switches to act as a 2 way switch. Main switches will be Z1 series. H1 is said to be more premium in terms of built quality and touch feel than D1 and E1 if that's what you are asking.
keith
thanks. but not exactly, as these sw are more for lights with lower current amperage, as compared to ceiling fans or laundry systems with a starting current situation.
ZacharyA
Unless it is an aircon switch (20A isolator), water heater switch (20A), or built-in oven power socket (20A). I have not heard that we need different types of switches between fans and laundry system vs lights.
louisho
hi.
i'm planning to get moes smart switches for my upcoming place. Anyone knows if Moes switch is able to do 2 way control (ie 2 switches to turn on/off a light source)? Will be having Neutral Wires for my switches as well
