ZacharyA
Got difference one.
(1) smart switches - usually use to on/off and do scene
(2) smart lights - can adjust color temp, dim etc
Some say no need smart switches, use smart lights, some say use smart switches. To me, you need both. But in the end I may go towards conventional (non smart). After I tested smart lights, quite difficult to use. If hub or internal down then game over. I tried Siri HomeKit (not easy to use) and Google (also got flaws).
Smart Switch can control a dumb light / fan point to control (on/off) remotely or via automation.
Smart Lights, then technically you don't need a smart switch. You can have a dumb switch and keep it permanently switched on and control the smart light on/off via the app itself.
It's like leaving a TV plugged in and turned on all the time and using the remote to turn on/off instead of manually flipping the power switch and then use the remote to turn on again.
Jas007
need advice on Aqara H1 WIRELESS Rotary Switch
1) can this control the T1 Ceiling Light? and if so to what extent eg on/off, brightness (dimming), change colours, etc ?
as well as the non-wireless equivalent … how’s the wiring like ? (like standard aqara wall switches, or more complicated ? )
TIA
enimen
When u install LED or RGB light strips, do u guys do concealed wiring to your smart switches so that you can on/off your light strips via switch? Or do you control them via smarthubs?
Is it advisable to do the former? (As an extra way to on/off light strips in case guests or old folks)
Ash
Hi all, is it a must for neutral wiring? My non-neutral Aqara China switches does not seem to last...
crazymond118
Which vendor did you purchase from? The magnetic track itself is it manufactured by them in-house?
I used the TB vendor that others shared in this post before. And the track itself is from Aqara, but seems there are some delay as they said will start shipping in early Sep but nothing til now
ZacharyA
AFAIK, Aqara doesn't manufacture tracks but the lighting fixtures / modules / controllers.
Deceased
Hi all, I have a portable ac which uses 2.4ghz remote control. Is there any easy way to be able to remotely control the ac on schedule?
Thanks in advance.
drkcynic
I have a question for smart switch electricians here please...
My home comes with smart switches. For 1 room, they are lined up in 3s, meaning I have 3 x smart switches (3 gang) setup across each other, controlling 9 light points. They are with neutral wiring.
Recently one of the smart switch was damaged (non-responsive) and I used a dumb switch (normal tic tac kind) to replace it. The dumb switch worked but the other 2 smart switches failed to work.
1. I suspect it is because the dumb switch (which does not need neutral wiring so I just left the neutral wiring dangling connected to nothing), broke the entire neutral circuit of all 3 smart switches and caused the other 2 smart switches to not work. True?
2. If I am to replace all 3 smart switches with 3 new dumb switches, meaning the neutral will be left dangling for all 3 switch holes, will the new setup of 3 dumb switches work? (only LINE and the OUT for the lights are connected).
Thanks!
ezihome
Thanks!
1. Based on the description only, seems like it. Seems like the neutral was branched off from the faulty smart switch to the other 2 switches. You can try connect the neutral of the faulty smart switch to the adjacent smart switch to see if it works or not.
2. Yes will work. Jus make sure to tape up the exposed neutral wires with insulating tape.
hkchew03
Thanks in advance.
Use universal RF remote that can learn command, trigger the command on schedule.
Colaice
Hi, I plan to install aqara swith switch and M3 hub, but some of the light will use Tuya light.
Can I control the tuya light dimable with homepod? or I have to buy one more tuya matter hub to control?
Or direct use the light with support matter will be better?
xgildedlily86
This i can help.
The hub must be global.
For switches and child devices no such thing as global. Any china devices uvget from taobao also will work. I see lazada and etc advertise global switch and mark up switches lol
But for safety go into aqara app and check under settings is the devices is able to be added also. Select region as others and not mainland china. Then u will be able to use google or alexa control.
Omg I was just so confused over this and you cleared my mind!! 🙏🏻🙏🏻🙏🏻 Means I can buy the switches from tb just buy the hub from sg and can connect already right?
anyone know of a hub for both aqara and zigbee that could possibly be both homekit and google home competible?
xgildedlily86
I also have issues with dimmers and light compatibility..
ZacharyA
Aqara must use Aqara hub, zigbee devices must depend what brand. Aqara has zigebee child devices as well. And you have other brands like Tuya platform or others (Singapore got many 3rd party).
I don't think there is a 1 size fits all hub. And you might need to use HA if you are going to cross platforms between Homekit and Google Home.
ZigguratZ
Hi Bro,
Need some help here.
Am using Tuya Smart touch switches for 1.5 years and yesterday one of it went offline totally, it cannot even be switch on manually...
Not sure why it happen and was wondering will I be able to switch it on manually if I changes it to those smart switch with push button?
ZacharyA
Hi Bro,
As long as the wire is not damaged, yes, you can just replace with another switch (smart / dumb) and it should work fine.
