alpha29
For Xiaomi device only available in their china server, able to link to Google for voice control? Somehow, I have many devices but only 1 of them is visible when mihome connected to Google.
keith
hi,
China items need to connect to Chinese server, and there is a side load method (region change) and will communicate back to Chinese server, leading to a slower response time than a local region server.
side: i have 4x Aqara (China) T1 window/door contact sensors to let go (3x BNIB, 1x new, opened for testing)
pm me, if anyone is interested, letting go at cost/slightly lower.
doki81
anyone have experience using a windows small pc like this to be the smart home hub? thinking to ditch google home / alexa and built one hub ..but torn in between rasperry PI or windows.
Audiology93
Hi fellow gurus. I will be collecting my BTO keys soon and would like to make my home "smart". What are the things that I should be on the lookout for to avoid compatibility issue? I'm currently looking at the following items from Aqara.
-D200i Digital Door Lock (for the facial unlock)
-D1 2 Gang No Neutral Switch
-M2/M2 hub
-Aqara LED Strips T1 (is this actually bright enough to lit up a living room/bedroom?)
-Ceiling Light T1M (might get this instead of T1 strip if T1 strip is not bright enough)
-T1 bulb (maybe for dining area lighting)
hkchew03
-M2/M2 hub
Avoid mixing China/global Aqara devices.= for best compatibility.
Typically bedroom use 24-36W LED, you need like 5-7m of the strip to even get similar power.
Plan your hub location for optmise zigbee coverage.
merriman
Gonna install home assistant into it? I used Home Assistant Yellow, based on raspberry pi. Stable and no issue encountered. Low running power.
Idling power should also be considered when choosing hardware.
Audiology93
Thanks for the advice. I will try to get all Global Aqara Devices. Will avoid the LED strip for now
doki81
Alamak I realised the remote control uses 2.4ghz to control my portable ac so don’t think broadlink can work. Is there any way to remotely control it?
what brand of aircon you using. suppose all should be standard.
for aircon, better to use sensibo.
Deceased
It’s a rather new brand “zero breeze mark 3”.
it’s not the conventional AC, it’s portable kind.
Devilsire
anyone tried zigbee rain sensor with solar charging
wondering how accurate is it before considering automation with blinds etc
yamashita
Moderator
Moderator
My friend is using Aqara water leak sensor but it's not entirely accurate as the floor might still be wet even though the rain has stopped.
ZacharyA
How many smart switch do u guys need to install for hdb 4 room?
Depending how many light and fan point you have?
If your room only has a ceiling fan + light combo, you only need a 1 gang switch.
Generally 1 switch per room is sufficient, MBR maybe 2?
Living Room between 1-2 depending on the number of lights you have and if they are grouped or separated.
Kitchen 1-2 depending if you split dry and wet / yard area.
