hexanol
- Apr 20, 2000
yep, cause of the same signal.... nvm, will try to explore, maybe can use for other DIY purposes too.
May i ask, if lets say u setup triggers/actions in raspberry PI with Hass.io.... can you do those if-else checking of the state of devices to determine the path to take ?
for eg.
if door sensor triggered, turn on door light if door light is OFF.
if door sensor triggered, no action if door light is already ON.
Thanks!![]()
should be able to if you look at states. However, you have to ONLY use hass.io to control your switches, if not it won't know what's the current state. e.g. if someone manually turn on the light, hass.io won't know. unless you have a light sensor somewhere to detect light.
