pajamasguy
honestly what to use smart plug for?
I use one of mine for my subwoofer. Normally the sub will go automatically to standby mode but mine has a bit of a problem and I need to actually turn it off completely. And most of the time I need to Off/On it several times in order to wake it up. So using a smart plug, I can conveniently do that on my sofa.
I also use them to turn on my small table lamps. They use E14 bulbs which only until recently we can find smart ones in that size.
I also use one for my phone charger so I can set a count down timer to turn it off after a certain period.
Revealed
If one uses Wi-Fi, I think when the Internet is down, the smart switches will not work. Maybe someone can help verify if you are using that?
I also like to add that when designing the smart home, it should be designed such that when the smart hub and network failed, all the smart switches, lights and plugs should still behave normally as there is no smart hub around.
medscy
Actually, if you are using home assistant/openhab, everything should be still functional even if Internet is down. Only that you can't access the HA system on the cellular network. But if the wifi is down, obviously everything is down... so it's best that the smart switch has a mechanical/touch button to control the switch in this remotely rare event.
Revealed
Ah ok. Thank you for the clarification. I had the misconception that if Internet is down then the home automation will be down too.
I am currently using Fibaro system. So far so good .
plustwo
You are right but there are still instances when it does.
1) When the power point Is too high or low.
2) When you have remote by your side but the appliance is at the other end
3) When there is ir blaster or smart home centre to integrate all appliances into 1 app for control
can buy ir/rf blaster to control #2 right? and never heard of anyone turn off printer before. standby mode dont really use much power right
Revealed
Ya. But I prefer having it fully switched off in case my kids play with the remotes or appliances and turn them on accidentally.
bullfrog
Fish tank lights, wall mounted/floor standing fans, Christmas tree lights. While not many, there are definitely uses for at least one in the home .
Posted from PCWX using Me dic stinks
Revealed
Oh ya. And there are situations where I may forget to switch off appliances and I only realised it after I left the house. In fact, it just happened to me.
medscy
Some appliances do consume considerable amount of standby power. So the smart plug consumes less than 1W (I'm using RF ones which are more efficient than WiFi ones), it will be better off having standby power for appliances such as your media players/setup boxes or even laptop adaptors.
https://www.cnet.com/how-to/vampire-energy-is-sucking-you-dry-heres-how-to-stop-it/
kpo kia
Anyone feel Amazon Echo is better than Google Home?
I using both at my home, but finds Echo responds/ uds me better than Google leh.
Thou the fun thing is Google can speak Singlish.
kpo kia
How much is this Fibaro system, can share? Must be very exp.
I am also looking at purchasing a smart home integration solution with wifi and lan. Very scared later electric down, all things would then not be so "smart" after all.
Revealed
For fibaro, I think it can start from 1k and then depends on how elaborate you want it to be. For my house, I quite a number of things. Other than lights and curtains, I also have like motion sensors and rain sensors. About 6k to set them up.
But so far it's good and quite secure and my wife is quite happy with the convenience so I guess it's good.
Revealed
Oh ya, I also installed ir blaster for aircon. Fibaro uses z wave so no it has it's own "mesh" network.
The switches can be manually used as usual so no worries.
I didn't get other system due to security concerns.
LesterQ
Can I use my Philips hue bulbs that I bought from US in Singapore? Are there lights that are using A19 bulbs?
Revealed
I am using Google. Can share in what way does echo respond better? I think I will still choose Google any time. Afterall they make OS for phones and I have 1 less compatibility issue to worry about.
Revealed
This is how I have set up my bedroom home automaton. When I call for movie mode, the curtain closes, the apple TV switches on, the projector switches on, the projector screen lowers down, and the ceiling speakers switches on.
I used Fibaro with TP smart plug and Google home mini.
Link to YouTube video>>
youtu.be/5VIqxcjrB6A
zoneguard
Has anybody tried Reality Switch with 86 size switches typically used here?
No need to bother with neutral wire and Zigbee based. And it claims to work with multiple gang switches..
Another different brand and implementation which uses BTLE
Switchbot
Revealed
As in studio apartment? For me I think it depends on your expected quality of life. If I can afford I would.
Imagine as you are near your house, the aircon powers up and you step into a cool room. Then as you walk about, only the light 1m away lights up. As you sit down and turn on the TV, the curtains closes and the sound bar turns on.
After lying in bed and reading, you can just call for the lights to be switched off and not have to walk to the switches. The next morning, the curtain opens itself to wake you up gently with sunlight. The coffee machine makes a cup of coffee as you step down from your bed.
This is only achievable with home automation.
Thanks for sharing the youtube link. For you - do you think its worth to get one for a studio pad?
