AsusEpoxy
think if you want energy monitoring, there's
1. Sonoff POW ( its 16A, abit low, but i am using to control aircon compressor, its been awesome stable for almost 5 mths so far)
2. Aeotec Heavy Duty Switch. Its rated for 40A but you will need a Z-wave hub to work with it.
zoneguard
How's the Switchbot? Does it work reliably, how long is the lag, will it work on large switches?
I'm not using the official hub. I just used a bluetooth dongle and the modified MQTT code to drive the Switchbot. As for large switches, my heater switch is the large one and because the default sticker (for the nylon string to attach to switch for switching off) will hide the neon power indicator, I only use it for turning on and not turning off. No perceivable lag. Size wise,
is probably a better fit for both turning on/off than my current switch which is a big rocker switch that covers 90% of the surface like this. I probably need 2 of these or DIY my own 3M sticker.
As for reliability I don't know as I only installed for less than 1 week. Was trying to figure out how to expose it to HA without using the native component.
zoneguard
Add to the list:
1. TISHRIC 16A which is basically a Sonoff clone.
2. Sonoff POW R2 rated for 15A.
3. Shelly 1 also rated for 16A. Somebody wrote a review somewhere in the thread.
zoneguard
A mod for Wifi switch requiring Neutral to be used where no Neutral is available by adding capacitors at the switch and load
The same link mentioned the caveats:
That scheme is for GAS or LED bulbs only. EW - you are right. LED and CFL bulbs have a wider input voltage range. That's why they are working fine, and you will not sence the difference. Do not use that scheme for classic bulbs. Classic bulbs will burn darker.
And your guts have good "premonition". This is not a best solution. Best solution is to "run a neutral wire and do it right". BUT! If it is not possible - it is better to do that scheme, but not the one with the grounding wire.
About heat - there are not heat at all on METAL-FILM capacitors.
Epi_curean
Do you have the link where you bought the Teckin SP23? It has energy monitoring?
I actually got the Teckin SP23 in carousell off someone who is selling the last of their stock. It cost me $50 for a 4 pack
Have not found it anywhere else in lazada or shopee
zoneguard
I saw from the Tuya-convert github issue you are interested in relays?
  1. https://www.lazada.sg/products/i295995024-s500049836.html
have the "Tuya App" keyword in their product details and more importantly, their pictures look like this tasmota template and somebody already figured out the GPIO pins. So a very good chance they are Tuya-convertable. But I haven't bought or tried them myself so I'm not sure you want to take the chance.
EDIT: Now I recall where I read the whole family of apps that use the Tuya cloud.
Alphas
can just change the resistor inside the xiaomi switch?
Actually, if you are adventurous, just get any compatible smart switch, desolder the 16A relay and replace with a 20A or 25A relay for your water heater.
zoneguard
Continuing on the Tuya journey:
digiblurDIY featured this RGBW BlitzWolf BW-LT11 LED strip in his latest livestream. At the 1 hr mark.
This works with GH/Alexa and the Blitzwolf app (which is Tuya based) and can be flashed with Tasmota via Tuya Convert and the template was submitted by digiblurDIY.
More importantly, it is sold at Lazada SG and Banggood and Aliexpress. I see this as a cheaper alternative to Yeelight Aurora LED strip which is Tasmota flashable. I'll be getting this soon myself.
Alphas
The picture looks exactly like my Hyleton 313. =:p
Actually the Teckin SP23 LED is at a different position - top right corner.
Yes, the picture is inaccurate, I bought it and the led is at the top corner.
zoneguard
FYI, the BSD29 round plug sold by multiple sellers on Shopee has energy monitoring as well and is approximately the same size. For the price quoted by the qoo10 seller for Teckin SP23, you can probably buy 2 sets of the BSD29.
sellun
How does the energy monitoring for bsd29 works? Is it able to keep history of the power consumption?
Sent from HUAWEI BLA-L29 using GAGT
zoneguard
Are you referring to the Tuya app? I don't know coz I flashed Tasmota as soon as I got my hands on the plug =:p
I use it with HA and the plug publishes the following attributes via MQTT to HA: today, yesterday, total energy in kWh and the power/voltage/power factor.
BlitzWolf SHP6
sensor:
- platform: mqtt
name: "Blitzwolf Energy Today"
state_topic: "tele/blitzwolf/SENSOR"
value_template: '{{ value_json["ENERGY"]["Today"] }}'
unit_of_measurement: "kWh"
- platform: mqtt
name: "Blitzwolf Energy Yesterday"
value_template: '{{ value_json["ENERGY"]["Yesterday"] }}'
- platform: mqtt
name: "Blitzwolf Energy Total"
value_template: '{{ value_json["ENERGY"]["Total"] }}'
- platform: mqtt
value_template: '{{ value_json["ENERGY"]["Power"] }}'
unit_of_measurement: "W"
- platform: mqtt
value_template: '{{ value_json["ENERGY"]["Voltage"] }}'
unit_of_measurement: "V"
- platform: mqtt
name: "Blitzwolf Power Factor"
value_template: '{{ value_json["ENERGY"]["Factor"] }}'
plustwo
i am adventurous. but idk wtf i doing :s13: what 20a relay are you talking about?
Alphas
All those smart plugs, sockets have a relay inside. The rating on the relay determines the max output current. Replace the internal relay to get a larger current output, and it should be of the same size and not affect the internal circuit.
Epi_curean
The advantage of the bsd29 as @zoneguard has mentioned is the small size and the energy monitoring ability. But its only rated to 10A.
The Teckin SP23 is rated to 16A so that may or may not be important to you.
I am no electrician so changing relays is beyond me, but I have read of people who did that.
On another note, has anyone flashed tasmota over Tuya type water leak sensors?
https://www.aliexpress.com/item/NEO...713.html?spm=a2g0s.9042311.0.0.623d4c4dLULGC2
If so, how to configure it?
I have managed to flash tasmota on Tuya type RGB GU10 bulbs
https://www.aliexpress.com/item/Sma...142.html?spm=a2g0s.9042311.0.0.623d4c4dLULGC2
Still figuring out how to configure it .
I use openhab.
