zoneguard
All these can be done with presence scoring. ie, I set a countdown on my water sensor after my shower, I set "scores" on a variable so if homey detects I was in the toilet more than 10min, water heater was on, and I just came back, it "guesses" I was in the shower and sets a specific temperature for my aircon.
HA has binary Bayesian sensor which does similar things.
On a side note, I have been trying to get facial recognition (with dlib) to work in HA.
Alphas
Has anyone bought this smart plugs before? It has a 4x sockets and can be connected to Alexa, IFFT and Google home. The square plug has energy monitoring. I just tried it and it works very well. THe app to connect is smart life, has both android and iOS version.
https://www.tuya.com/
I found the OEM for this square smart plug with energy monitoring is Nanxin.
http://nanxin88.com/product.aspx?id=115
They are the OEM for Teckin smart plug, which is in the list of compatible devices.ill be cool to convert this to Sonoff
https://github.com/ct-Open-Source/tuya-convert/wiki/Compatible-devices
zoneguard
My Hyleton 313 plug is also a square plug but with the LED at the bottom centre of front face rather than at the corner of the front face.
viix
same concept, but can be confusing for new users..
punkster
I see only live and ground. No neutral.
Tell your electrician to run neutral to all ur light switch points. I'm about to do my reno and the electrician quoted me 60 bucks each switch point.
I'm now considering to buy the xiaomi aqara with neutral since nobody has experienced any burnt switches with those so far.
can i check when you run neutral is the wire definitely visible (ie trunking outside) or can be hidden? I got a feeling my ID is smoking me.. :s13:
bullfrog
:s13:
Mine hidden together with the live.
Posted from PCWX using Me dic stinks
zoneguard
Turned out the BSD29 plug has energy monitoring as well. List of plugs which are available from Shopee/Lazada that are Tuya-convertable from reading the Tasmota/Tuya-Convert wiki/Tasmota Discord/forums:
1. BSD29.
2. Hyleton 313.
3. W-UK007S.
The list is probably longer. If you see "Tuya app" mentioned anywhere in the product details, there's a good chance it is flashable.
There's a list for bulbs/LED controllers but currently it is US standard bulbs mainly.
Epi_curean
How did you configure the BSD29 to have energy monitoring under Tasmota?
I got the W-UK007S working as Blitzwolf SHP but cannot figure out how to get the LED lights to work properly
cheers
zoneguard
cheers
1. Use Tasmota import template feature and this value
Code:
{"NAME":"BSD29","GPIO":[0,0,0,0,134,132,0,0,21,17,56,131,0],"FLAG":0,"BASE":45}
You need to calibrate afterwards. Instructions here
2. Again use the template feature, base it on Blitzwolf SHP and modify the GPIO mapping for Led1, values from here
Code:
GPIO0=Led1i
I might get the W-UK007S since it is rated 13A. Can you confirm the power rating?
DEBUG
Hey I'm thinking to install a smart switch to replace my HDB big button meant for water heater.
So far I see smart switches are meant to be use on lights and stuff.. Will it also work for water heater switch or I need get something special.
Please advise.
Reason why I want to do this is because I'm using a heater tank type which means I always have to switch on heater to heat thr water then off it after like 15mins or so.. Sometimes on the road so good if I can remote on it or set timer to auto on and off it so come home have hot water for shower.
zoneguard
Please advise.
Ref
1. Change to 20A RF switch if you can still find them.
2. Add Electrical contactor with RF/Zigbee/ZWave/Wifi light switch.
3. Add Switchbot/Microbot Push or similar. Add hub if required.
Epi_curean
Code:
Code:
GPIO0=Led1i
Thank you. I am on 6.4.1 tasmota but I do not see template configuration , where do I find it?
UPdate.. i figured out. need to flash the development firmware
Yes, the W-UK007S is rated for 13A but its design makes it larger and may not accomodate a side by side in the 2x powerpoint. So far, the Teckin SP23 is the most convenient in terms of flashing and form factor
nets
Please advise.
Im currently using etouch 20A switch, brought from Carousell - the seller is merelysmart. Its working well and able to supply for my heater and venti fan. I think your idea is workable :) but i usually prefer automate the off function only, not so much for On function, since i gather even if it off incorrectly, it doesnt do any harm (at least doesnt cost me any extra power cost).
Cheers!
plustwo
Ref
can just change the resistor inside the xiaomi switch?
zoneguard
Have you used any of the switchbot you have mentioned? If so, can share your experience?
I'm using the Switchbot to turn on the storage heater. HA has a native component but I'm not using that due to the limitation the bluetooth dongle needs to be in the same machine as HA to use that. Apparently the Switchbot is popular with some Japanese as I found a few code/Youtube examples of its usage so I modified a Japanese's MQTT client for Switchbot for my own purpose and on the HA side used a MQTT switch to control. For the frontend, I used Telegram to remotely turn on the heater when needed and also have automated a scheduled switching on in the morning on working days.
zoneguard
Do you have the link where you bought the Teckin SP23? It has energy monitoring?
pustefix
How's the Switchbot? Does it work reliably, how long is the lag, will it work on large switches?
