Official ZenFone 5 Thread
david_yyy
Hi Bro,
Can you share the url to download the battery patch for KK. Btw, what is the FW version after the battery patch? Currently, my FW version is 2.19.40.18_20141003_8008
wackykid
Hi Bro,
url? just do system update... if got new one u will be prompted to install...
well my software information is:
baseband: 1434_1.4.39.2_0922
kernel: 3.10.20-262908-g3ebb293
build number: 2.19.40.18_20141003_8008
My zf5 has this problem. For no reason the phone will be hot n batt drain fast. I can feel e heat as it is in my pocket.
get the latest firmware (if u have not done so...) ...
regards,
wacky
africatwin
regards,
wacky
Did the upgrade last night. Was at 80% and now 67% with phone on standby thru out the night. Guess not much difference after the upgrade.
africatwin
Not sure if anyone encounter. My zf5 will kok up if i use dual sim. Was using my office sim with personal sim.
Initially, everthing is fine so happy. But soon my personal sim will lose signal and not working at all. Do so much setting and even check with my ISP SH. My sim is working n nothing wrong.
Since that few days of problem solving i stop using my dual sim simultaneously.
Very dissappointed.
david_yyy
Hi bro, thanks. I am having the same build number as yous.
david_yyy
Hi, for me no issue using both sim even after upgrade to kitkat, in fact, battery life about the same, only thing is my installed app no longer able to write to sdcard due to google's policy.
Very dissappointed.
africatwin
Think i have to sent in to service ctr liao. Dual sim is really convenient but giving me quite abit of problem from my zf5
Mng85
Any idea how to remove the slide to unlock when you power yr phone from standby mode... no such issue b4 update to kk..
wadsad
gps indeed quite weak for this phone. i use sgbus also got problem.
screen brightness also another issue. dim not dim, bright not bright.
battery jiak damn fast also.
but still this phone is one of the best in the price range.
africatwin
Agreed even after e last firmware upgrade the battery life is still battery.
Still the phone heat up even when screen is off.
megaweb
totally not working... updated the messaging app today... my OTPs are still being blocked... no difference watsoever... :vijayadmin: i also disabled unknown call blocking liao... no idea where else is there where by can seperately control SMS blocking (if this even exists) ... :mad: :mad: :mad:
regards,
wacky
Encountered same issue as you yesterday while purchase item online and never receive any SMS for OTP. Later found it at the blocked folder.
V
victorlht88
Guest
if phone heats up when screen is off, there is probably a rogue app running in the background thats why.
Backlash
Is this phone still worth a buy ? I m pretty interested in the 16G LTE version. Any recommendation ?
muneer
New update to the messaging app to solve this issue. Try it?
Wouldn't actually recommend the LTE version due to the fact that it has the same battery capacity as the 3G version.
megaweb
My zenfone 5 has already updated to the latest firmware and still encounter same issue. Look like kitkat is not as stable.
After unmount external OTG, the app installed in SD cannot open. Need to un-mount and re-mount SD to work.
Sen
anyone interest in a zenphone5 LTE (white/16GB/2GB)? One month old selling @ S$230. The plastic back got a slight dent cos got drop before.
muneer
The messaging app can be updated via the play store. The SD card issue happens with other phones too so it's no surprise.
Asus is working on bringing Android L to the Zenfone series.
