One Key token low battery
havetheveryfun
my one key token say battery level 0 since 6 months ago but until now still can use
stjoe1
Free for the 1st token, after that replacement needs to pay ..
Dun know if go there can be free ..
The cost and time to go there may not be worth it ..
Steyr69
No need to pay if you go to them @ PSA Building (Alexandra Road) or International Plaza (Anson Road). At least that's what I was told when I called them.
http://ifaq.gov.sg/SINGPASS/apps/fcd_faqmain.aspx#FAQ_182240
Thank you.....Anson Road is city area....still ok.
if we lost or misplace, ask for replacement, pay i no issue.
if low batt, should be free....
MrConfused
Replacement is free if your token runs out of battery. They have a system to check when did you receive your current token. The waiting time at International Plaza can be quite long (more than 30mins) though.
MaoZeDuo
Bank token since 10 years ago still working but this token so fast low batt?
RM2SSG
Mine also battery low and I went online and realised there is a Onekey Mobile. Downloaded the app but keep crashing on my iPhone 6s with iOS 11.0.3 Have not been able to try it out.
nwh_sg
my token also showing sign of battery low, display getting dimmer.
@#$%, battery died 2 days ago. Now can't access my online trading on PC, can only use hp. So troublesome needs to go down to get a new token. They should just mail it to us as everyone's token battery is gonna die around the same period. I am going to disable 2FA using this stupid key. Use SMS 2FA where option available.
peacefulday
You can called up brokerage service helpline to delink 2FA token and done in sec.
