OnePlus 8/8 Pro!
ongkc66
Mine is even worse...
1. Install Gpay Singapore and contactless payment works (not transit)
2. Prompt for update and updated
3. Stuck at Gpay screen
4. Reinstall and issue in item 3 solve
5. Prompt for update again and updated again
6. Stuck at Gpay screen...
Seriously...?
Vulpix
Moderator
Moderator
Seriously...?
This one not your phone problem unfortunately. My Pixel 3 XL also keep getting stuck with the new google pay SG app, had to uninstall, reboot phone, then it finally worked. Kept freezing at gpay screen also.
suxalot
You can go to app info and clear storage and cache. Then relogin with your OTP. I know is a hassle, but less trouble than deleting and reinstalling the app.
Seriously...?
kryptonit3
where to order whitestone for op8p? i can;t find it anywhere.
if this is 27 days ago, should be soon ?
kryptonit3
Gpay still not stable works on entry, exit tio stuck. Works again on bus ride.
Posted from PCWX using IN2013
KeYoKe
Wait them update the gpay ba...
I can almost hit 100 percent success. Just sometimes the scanning time is long before the reader detects
Aikon
Just to eliminate any user error, you know where the NFC reader is just around where the OnePlus logo is, where the wireless charging element is, according to the video.
Lol I remember having poor detection with the note 10 initially as I switched from the S10 and the NFC was in a different location.
So far I'm loving the OnePlus 8 Pro... Looks like my find x2 pro may be sold soon.😀
Haven't tested the Google pay yet though. Maybe later this evening.
altca4
What do you like about one plus 8 pro vs find x2 pro?
Aikon
One thing, it's lighter. Understandably the find x2 pro is ceramic so it's much heavier and bulkier. The find x2 pro has better build in that sense. But damn it's really heavy in the hands.
Oxygen vs color os... Color OS to me still quite cartoonish. Think this is why I prefer it.
Speaker wise, it's slightly louder than find x2 pro. Think oneplus boosted the sound.
But :
Find x2 pro has better camera hands down though.
Screen on the find x2 pro is better, the brightness is really high. 1/4 brightness on find x2 pro is equiv to half OP8Pro.
LOL.. If they are using the same screen, it's like OP8Pro is using find x2 pro rejects 🤣😂
Find x2 pro has better value for money because if you pay street price which is the same as the oneplus 8 pro local set, you're getting double the memory 512gb. And 2 year local warranty 😁. VOLTE and call recording out of the box, though OP8Pro require hack.
suxalot
Just tested on public transport train. NFC works on entry but not on exit. This is annoying.
