OnePlus 8/8 Pro!
KeYoKe
Ahh. I noticed my icon always keep switching between volte and vowifi. Do u also face the same as well? My phone was connected to WiFi at home.
If u r connected to wifi, then your phone will show vowifi. If u are outside using your 4g, it will show volte
angtc11
Can I use check for op8p users, if you are at a location with a recognized wifi (but not logged in,eg wireless@sg), does your mobile data icon show 4G?
I encounter a problem where I frequently cannot get mobile data and it appears that the phone detects the wifi (even though I am not logged in) and stops using the mobile data. So for example, I don't get 4G icon at home, outside bedok mall, outside bedok point, McD, bedok hawker centre. I step 10m away and the data is restored
Appreciate if anyone can share their experiences or the solution if any, thanks in advance
tc4237
Anyone knows where I can the oneplus warp wireless charger?
The one plus official site doesn't ship to sg.
nexusscion
huh OnePlus 8 series by default cannot be connected to VoLTE?
Need to enable the setting in the phone via PC to show the option in the phone. it is rather straight forward. After that, the setting will remain on the phone as an option to trigger on/off
rollanddie
How much you guys got your op8/8pro for?
Currently still using 5t but looking to upgrade liao, battery getting cui
nexusscion
Price is 1.39k for a 12/256 GB spec. I think the official lazada store is out of stock when i got mine few days back. You can try other shop
Kitaro9202
Ya quite expensive actually. In fact my 20w xiaomi charger is charging it effectively well. Getting almost 1.3-1.5k mA which is quite decent for wireless as most wireless qi pad only charge around 600-800 mA even it says 10w fast charge
Previous I was using huawei phone so I got their fast charge quite cheap abt 30+ sgd
I also have baseus wireless charging
