OnePlus 8/8 Pro!
leowweiqi
yeah i don't like pop up camera, mechanical part will fail over the time. pouch thru is better , way better. considering i am planning to use it for years
Battery which is non mechanical also will fail over time
Aikon
yeah man. my first 1+1 made me reject all other Android phone. i can only settled with the phone that 'never settle'...
who here is waiting for 8t/8tpro?
Yes, I didn't quite like the Oneplus One (and the invite system) though. 1 bought 2 sets and they both had yellow "piss" (yellowish screens) as they were described then.
Didn't go back until Oneplus 6 and then I've been hooked again since then... Waiting for 8T though I'm presently using the 8 Pro which I love 😍
lol. i do not need wireless charging and also ip68. that make me settled with 1+8 will do. save money :) 90hz is fine. i don't have bionic eyes that i can find flow in 90hz that i must use 120hz... hehehe
not sure did you receive my PM
oneplus 8, 12/256 variant black
sealed shrink wrapped if you are keen
Kitaro9202
Weird when I was browsing on some website my display like sudden turn into blue light filter eh
Iceman127
Anyone know how is the camera now between 7 Pro and 8 Pro.
Are both similar or great difference?
meowth82
any good deal for OnePlus 8 128gb model? Roughly what is the price range for this model at the moment?
iDexPro
8 Pro has a better main camera sensor than the 7 Pro. The 8 Pro's ultrawide cam uses the same main cam on the 7 Pro. 8 Pro uses the ultrawide to take macro shots, 7 Pro does not have that option. Both probably have the same telephoto and selfie cam.
I would say that the main cam performance on the 8 Pro is better, but not by that much. Just mostly better color processing and more sharpness on the 8 Pro to make them look realistic. However the ultra-wide on the 8 Pro is much better. It is much sharper, and also has a wider FOV.
