OnePlus 8/8 Pro!
WoShiPro
Can get OnePlus 8 non pro at $869 with $30 voucher from Shopee.
Personally i think OnePlus 8 good enough for me.. upgrading from s8.
WhiteAnt
worth to upgrade to 8? 8Pro over budget... am using 7T lol
Not worth, no significant improvement
Unless they upgrade the camera(same as op8p or better), else it can never be flagship
To me wireless charging not imptt, but ip rating is. Just my personal thoughts, ofc have both are best but they need to cut corners somewhere to make it cheaper :o
anthonygreenisreal
Not worth to upgrade from Oneplus 7 series. The cost to upgrade is too much even if you sell the OP 7 series coz the resell value is really low in the first place and plus this pandemic. Might as well keep it and just use it until end of life.
Justbear
I am saying good to have 30w wireless charging enabled on one plus phone.
No comment on that one plus wireless charger
Sent from OnePlus ONEPLUS A6003 using GAGT
Even the wireless 30w only works with Op wireless charger. You wireless charge with others, it will be 5w.
Kitaro9202
I think wireless charging must get the manufacturer brand for their quick wirless charging
I using huawei p10: should be a great upgrade for one plus 8pro
nexusscion
Definitely a big leap. Upgrading to P40 pro is already miles apart. :s13:
