OnePlus 8/8 Pro!
xavierica
It still can charge although not at wrap charge speed right?
If charger support quick charge 3. it should be able to charge at 3A?
Yes can still charge but not wrap speed.
The quick charge one I think can
Sent from OnePlus 5 using GAGT
chooyoshi
dont know must up this post how many times... :s13::s22:
If they were sold by our telcos here would it be popular?
Too bad they don't have microsd. If not I might have put it in my consider list, although I'm eyeing the xperia 1 ii.
WoShiPro
Cheapest I can find is $869 which I bought yesterday from Shopee. Same seller as qoo10 but cheaper.
Now looking for Case/TGSP any recommendation?
smallboi09
Be careful of such shops claiming to sell "Global Rom" with Local Warranty..
It is actually just CN set but they flash OxygenOS/Playstore for you, and the warranty is a the shop warranty instead of the Local OnePlus Warranty (tbh not sure how good is the local support here)
WhiteAnt
Need to get fr reputable seller shops :o
It's okay to let them open up and flash to global rom imo like my op7. I also duno how to do it lol. Unless you wanna do everything yourself but not sure if they have those untouched sets
I just want to get the phone and use it straight without any added hassle. I believe that's what 95% of the consumers want ba :o
They say buying export set is as good as no warranty. So you need to assess your risk adverse. That's why I feel if the phone is too expensive, I wouldn't take the risk coz last yr I took a risk of &$600+ op7 and glad it's still working fine right now :o
WoShiPro
Where? Can sic?
Posted from PCWX using SM-G986N
https://shopee.sg/product/153680060/7228772893?smtt=0.0.9
Can get at $820 with $30 shopee voucher..
I bought from this seller at 869 when it's was 899..
Q10spy
Can bring further down to 810 using $10 bank voucher
This seller replied in Q&A that their set is an export set flashed to Global rom
