OnePlus 8/8 Pro!
PrincZe
Sent from OnePlus IN2020 using GAGT
kryptonit3
Yes it is the wireless charger. Seems fine
did u notice the blue led after charging to 100% would not turn off..not sure but I notice the phone is still warm after leaving it charging overnight on bedtime mode.
tc4237
Same. Nv turn off. And heats up. Not sure if it's due to casing. With casing also like charge even slower.
chook94
Any idea to get tempered glass screen protector for one plus 8 pro in Singapore physical local store ?
Kitaro9202
My phone went siao
First time random music from my Bluetooth den my screen is like cannot turn on after few min phone ok liao den i went to reboot
2nd time when connected to Bluetooth device, random play some whatapp voice msg, I close all app but the voice msg still play reboot phone ok liao
eskimobster
I'm using OP 8 and currently experience intermittent sms did not come in. Need to restart and only sms can receive. Anyone experience that? I using Singtel. Always found my otp did not receive. Tried use another phone send sms also can't come in and go out as well. Only after phone restart.
I'm finding this issue too. The 4g icon will have ! and no data or SMS received.
Just switched from 5g auto to 4g auto and will see if it helps
athenodorus
Can it fit with the sandstone case?
And how's the swipe gestures from the side, do you feel the edges of the glass?
Whitestone dome is available soon.
https://www.whitestonedome.com/blogs/news/oneplus-8-pro-dome-glass-is-here
