OnePlus 8/8 Pro!
firegazer
omg so just need to reflash OOS 10.5.10 IN11AA to local set
How to reflash OOS? I look up online and found it needs to unlock bootloader, which means complete data wipe? Any easier way without data wipe?
Sent from OnePlus IN2023 using GAGT
igarashi
yeah wanted to ask this too. Any simple guide to reflash ROM. I dont mind wipe data since new phone still not much data yet.
Or anyone can provide reflash service ? haha treat you a Starbucks coffee
igarashi
Just got an email from Oneplus. Shared with them the Oneplus forum post as well.
This their reply.
As per your query I would like to inform that this issue is already escalated to the concerned team and they are working on it. It will be resolved in the next OTA update. I kindly request you to please spare a little more time to get this issue sorted out.
Let wait and see.
winnub
Guide to enable VoLTE
1. Download these 4 files:
QPST (Install on PC) - https://androidfilehost.com/?fid=11410963190603912872
Qualcomm Driver (Install on PC, select WWAN option) - https://androidfilehost.com/?fid=11410963190603864074
Oneplus logkit (Install on phone) - https://forum.xda-developers.com/attachment.php?attachmentid=4763657&d=1558542807
Oneplus Engineering Mode (Install on phone) - https://www.apkmirror.com/apk/onepl...-0-171117173719-25c8842-android-apk-download/
2. Install the files as mentioned on PC/Phone
3. At phone dialer, key in *#800# > oneplus logkit > Function Switch > Tick "VoLTE Switch"
4. Reboot the phone
Gotten a used OP8 China set for a week. Followed your guide to enable volte and volte is enabled after i perform step 4. G Pay on transit works well, only encounter missed exit on bus yesterday. G pay respond when i tap out but bus reader does not respond
firegazer
This their reply.
Let wait and see.
Fingers, toes & eyes crossed.
smallboi09
My friend using Pixel 3 also told me that his GPay cant work on Public Transport - got vibration, but cant get through. Able to make retail payment. Seems like its a software issue with LTA?
firegazer
I tried again ytd on LRT gantry, now is totally no scanning and reaction at all. Previously I got a scanning screen and vibration but error, now is nothing.
kryptonit3
don’t think is related doesn’t explain why my export set works all the time. well just have to wait patiently for the update as mentioned, or just self reflash since it doesn’t void warranty unless you soft brick your device.
xavierica
I updated my reflashed OOS 10.5.10 to 10.5.11 via local upgrade. It broke my gpay for public transport.
suxalot
Mine seems fine. The latest system update supposed to enhance battery life even further, but I don't see a difference.
For those having trouble with public transport. The following combination worked for me:
1. Enable non-standard NFC Tag support in developer options.
2. Use only Google Pay, not Google Pay Singapore.
anyone has huge batter drain? my OP8p drain about 4% with barely 10min use =(
kryptonit3
previously did you flash directly to 10.5.10 or to the very first release and update from there.
Sent from OnePlus IN2020 using GAGT
lawreo2002
If don't use Google pay SG you will not enjoy cash back from transactions. I already got 20 bucks cash so far.
kryptonit3
the problem does not lie with the Google pay app.. no matter Google pay or Google pay SG should work..the bug is within the default factory flashed OS
