OnePlus 8/8 Pro!
crazyrobot
Gpay on public transport is not working. Had contacted Gpay support. Advise to remove and add the cards all over again.
seanyboydad
I drive most of the time and so has not used the function till today. Gpay (sg) version works for me. Using a OnePlus 8 export set.
Sent from Relax Dude......Dun Be So Serious using GAGT
kryptonit3
Lol should set a sticky to warn the Gpay bug since launch.. (look for oneplus support only) applies to local not export sets. :s8:
hello2ew
Returned to this thread after a long while, didn't know that GPay on public transport was causing problems for local sets. Have been using an export OP8 Pro (IN11BA) since late April, used it extensively on MRT and buses with no issues! Usually aim around the camera lens like my OP7.
Posted from PCWX using IN2020
leowweiqi
Europe rom no issue
rootz
For gpay, I installed via the one in Playstore (Google Pay Singapore). It works as well.
Do try and see whether does it help you.
Also get to earn the rewards.
Kitaro9202
How much? The glue last long anot?
69 dollar
49 dollar is ownself paste but I don't know how to paste well so opt for them to do for me lor
The protector came with the uv light filter thingy
They also got zeelot but told me impossible to fix cos of the gap is way too tight
Posted from PCWX using IN2023
lawreo2002
I was using zeelot. Forgot the exact price but was around $4X including installation. I like zeelot cause its very thin and more seamless with the phone display. I recall when I was using WSD for Note9 WSD is very thick. It's def more durable than zeelot but you can feel the heavy bump at the edges especially when you need to swipe. I also changed to the one from Mr Mister and it is just as good as zeelot
may I know where you installed the zeelot? Thanks
lawreo2002
Casefactorie at Bras Basah
*Accidentally deleted my previous post. Wanted to correct spelling for Mister Mobile.
Thanks bro. You mentioned you also install the one from Mister Mobile and feels the same as zeelot? Mister Mobile one seems cheaper by a lot. Is it as thin as zeelot? Thanks
Kitaro9202
I actually went to mister mobile at Hougang they say can't fit properly the case
minuteez
Do you guys know if theres shops that has the OP8 on display for us to look look touch touch? Mister mobile got display sets?
