OnePlus 8/8 Pro!
Kitaro9202
The sms got problem isit
I keep receiving the same msg from bank that i have transfer money to some one lo
Since yesterday till now receive a few same msg leh
Yes i make a transaction but I have check with bank and they say only send 1 msg only lo
Kitaro9202
Seem like is Google msg got problem lo
Using 1 plus messenger no problem
xavierica
I downloaded the a11 update from oxygen updater app. Flash it using local upgrade. I am rooted w magisk 21. So far no problem w public transport (hopefully). local set
Sent from OnePlus IN2023 using GAGT
dappercivility
Mine is IN2023 which I think should be India set. Updated via OTA and seems to be ok. Hopefully all is well. Also have 5G after the latest update. Am on M1
warmstone
Just tested mine by pressing power and vol down button. No issues. Any other ways of doing screenshot? Like swiping screen right to left like Samsung?
Icic, I tried using yr method, it works
Usually I SS using the option from Accessiblity Menu..now it doesn't work after the 11 upgrade
xavierica
U can toggle the 3 finger swipe for screen shot in " quick gestures"
