OnePlus 8/8 Pro!
lawreo2002
I have updated to 11. I noticed when I type messaging, there is these Google Assistant corner lines. May I how to remove them or stop them. Looks annoying.
Sent from OnePlus IN2023 using GAGT
tc4237
How did yall get the update sia? I'm still stuck at 10.5.13. Waiting for ota update notification for a few days liao.
xavierica
Oxygen updater app. Can dl from play store. It pulls ota updates from oneplus side directly
athenodorus
Try factory reset first bro
Yea tried. First attempt worked. But I won’t go saying it’s resolved until it’s consistently working. Let me monitor few more attempts.
Update: tap in and out twice both are working with no issues.
KeYoKe
Yea tried. First attempt worked. But I won*********t go saying it*********s resolved until it*********s consistently working. Let me monitor few more attempts.
Great. Keep us posted. Else i need escalate again liao :s22:
igarashi
There's hope for us liao.... hopefully
Wl319l
Is it safe to say the only issue plaguing OP8 Pro is gpay? Any other issues that y'all have faced?
KeYoKe
Guys, i will strongly recommend a factory reset after upgrading from Android 10 to 11 to remove any possible causes of issues related to the update
I will usually recommend a full clean reset especially upgrading from 1 android version to another as this is a major jump in version and oneplus did a major revamp on their UI
eskimobster
I tried system>reset options> reset app preferences and now it seems to be working for now for 2 trips.
Takes about 2 seconds placed at the gantry to detect but works.
This way possibly don't need to do a full factory reset.
Anyone else can test?
athenodorus
it shouldn't take 2 seconds to detect one..normally it's almost instant..
athenodorus
Yes got hope Liao. Upgrade to 11 then do a full reset. Now the goat is working fine.
I hope it's gonna be always working in future. Later another update and back to square one then no point.lol.
eskimobster
Important thing is if it works...can live with the minor inconvenience.
The other day it was just scanning forever and never detected.
Can confirm if do a full factory reset the detection is instant?
Mine was working on android 10 but similar scenario, normal purchase gpay instant, on transport take 1-2 sec to detect.
athenodorus
Mine after reset it scanned instantly. Before reset would be spinning for few seconds and after adjusting here and there then work.
WoShiPro
Export set after upgrading to Android 11 Simplygo/google pay not working anymore.. previously using international google pay. I also downloaded google pay sg but cant seem to set google pay sg as default contactless app?
will try factory reset as mention by other that it work.
